Transistors for Igniter or CDI or TCI or Ignition box or or or.......!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-23-2010, 02:20 PM Thread Starter
Exclamation Transistors for Igniter or CDI or TCI or Ignition box or or or.......!!!!
Hi all! I'm from Argentina, my english is poor and I hope you understand me.
One transistor (of the IC ignitor) brokes and I don't know how type is it, or code number, because it's erase. Somebody please can send me this info?
badalari is offline
post #2 of 15 (permalink) Old 03-23-2010, 02:24 PM
I understand what you are asking, but don't have the answer you seek. have you looked at ebay for a new Igniter?
post #3 of 15 (permalink) Old 03-23-2010, 02:55 PM Thread Starter
Just wants to repair it. New igniter cost a lot of $$$ here (USD 4 to 1 in Argentina)
badalari is offline
post #4 of 15 (permalink) Old 03-24-2010, 07:19 PM
Best of luck. I don't know either. The igniter is the one super expensive electrical part on the VN750, and as far as I know, it is a sealed unit, and is not repairable. I'm an auto mechanic, and have "black boxes" fail constantly, but I just replace them. Unfortunately, if the igniter failed on my Vulcan, all I could do is replace it as well. I have seen used igniter units on eBay for WAY less than a new one, but with parts like that it is impossible to tell if they are any good until you install them. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 15 (permalink) Old 03-24-2010, 08:34 PM
Jerry, The ignitor is repairable, but as with trying to find the diode information... the only way for me to figure it out is to open it up.
If man can make it, Man can repair it.
As for figuring out the right Transistor... which one is broken. how many are inside the igniter?
post #6 of 15 (permalink) Old 03-24-2010, 08:40 PM
You could very well be right, I never really looked at it. Fortunately I've never had one fail. Is there a way to get them apart, or do you have to cut them open? I have found a lot of such parts completely molded into a solid block of epoxy. Jerry.
1979 Vespa P200E
post #7 of 15 (permalink) Old 03-24-2010, 09:24 PM
it is held together with plastic rivets, the same as the JB... all you do is drill them out, and then reseal it up with epoxy and rivets. it makes for a lot better seal than stock. after poping open my first JB, i was shocked to see how much moisture was allowed inside the unit because it wasn't sealed right. so I popped open the Ignigter and the RLU to find them sealed the same way... resealed with an epoxy and rivets... no word yet if this helped or not.
post #8 of 15 (permalink) Old 03-25-2010, 05:23 AM
Badalari, you are not going to find the type information anywhere.
I suppose you are talking about a power transistor driving the ignition coil. The problem is that it could be a bipolar transistor (darlington most likely), a power MOSFET or an IGBT. Each of these have countless different types with different specifications. Then there are numerous different case styles. If you can tell the case style, I could suggest some types you could try, but the chances for them to work are still low. On the other hand, the worst that can happen is that you spend some money and end up where you started.
pappa is offline
post #9 of 15 (permalink) Old 03-25-2010, 08:50 AM Thread Starter
jerry/slimvulcanrider/pappa:
ignitor have only 2 transistors for ignition coils, just want the transistors code!
please someone, open ignitor's case (it's easy!), read the impresed code in the transistor body, and send it to me!
mine are erased, that's why I want to know transistor's code! to replace it!
just want the code!!
tks!!!!
badalari is offline
post #10 of 15 (permalink) Old 03-25-2010, 08:12 PM
already have... and as you noticed.. there aren't codes on them.. Kawasaki didn't want us to know what they are. hence no codes.
Tags
cdi , igniter , ignition , ignitor , transistor
