Turn signal install - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-23-2010, 12:00 PM Thread Starter
Bandito
Mellow's Avatar
Turn signal install
I got my new turn signals in and went about trying to install them, I noticed it is a very tight fit in the back where you have to turn them 45 degrees to lock in, it almost felt like the plastic was going to break before it turned, is this normal?
I got these: http://cgi.ebay.com/ebaymotors/NEW-T...Q5fAccessories
1993 Vulcan 750 - SOLD
1996 Suzuki Bandit 600 - Current ride
Mellow is offline
post #2 of 5 (permalink) Old 03-23-2010, 01:19 PM
Yes that is normal, use wd 40 to help reduce the friction.
post #3 of 5 (permalink) Old 03-23-2010, 06:04 PM
The Professor
lance328's Avatar
I took a razor knife and angled the leading edge, worked great.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 5 (permalink) Old 03-29-2010, 05:29 PM Thread Starter
Bandito
Mellow's Avatar
Thanks for the tips, I did take a razor and angle the edge and used WD40 and it worked, replaced 3 without an incident, took out the front headlight to make connecting the front turn signals easier.
Mellow is offline
post #5 of 5 (permalink) Old 03-29-2010, 11:44 PM
OldBikeNewRider's Avatar
Just replaced mine as well and had the same problem on one of the front signals. I just took a utility knife and trimmed a small slice at a 45 degree angle and it fit fine. Now that I have good signals I am thinking about taking the next step to LEDs for the brakes and turn signals and maybe aroudn the license plate. I've got the bike cleaned up pretty good now and it's just perfect. I really like the style and everything about it. Pretty cool!
OldBikeNewRider is offline
