Turn Signal Wiring question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-17-2010, 08:48 PM Thread Starter
Thanks for reading this. I am in the process of replacing all 4 turn signal indicators on my 85 VN750. My replacement signals have 3 wires (for the front lights) which are red, black and black/white. The wires on the light I removed are blue, gray (or a dirty white) and black/yellow. The wires which they were connected to are blue, green and black/yellow.
Connected like this
signal--------bike(wiring harness)
blue----------blue
gray----------green
black/yellow-----black/yellow
My question is, where do my new signal wires go? I'm guessing black/white---black/yellow, but I'm lost on the others and don't want to screw something up. Thanks for the help.
mjovovich is offline
post #2 of 7 (permalink) Old 03-17-2010, 09:00 PM
you wont mess any thing up... but to make it easier... take of the lens cover, pull out the bulb and look at the contacts... double checking that black/white is the ground... if it is the ground, then the black/white-Black/Yellow is correct, red is usually the marker lights and the red is usually turn signals... I would replace the front ones one at a time to verify with the other side as you do the wiring.
post #3 of 7 (permalink) Old 03-17-2010, 09:02 PM Thread Starter
Thank you very much for the quick post!
post #4 of 7 (permalink) Old 03-17-2010, 11:03 PM
OldBikeNewRider's Avatar
I am glad you asked the question. As soon as the wheather gets just a bit better and I get some time, I am changing my signals too. The old turn signals looked like the rubber boots just rotted or the bike was laid down to many times since every turn signal was wrapped in electric tape to keep them together. I'd like to put on some added running lights but just a bit hesitant to with the limited electrical output the bike has.
OldBikeNewRider is offline
post #5 of 7 (permalink) Old 03-18-2010, 11:01 AM
I have all 4 oem turns for sale... 40 dollars shiped
post #6 of 7 (permalink) Old 03-26-2010, 08:31 PM
Send a message via Yahoo to jdamato1
What bulbs should I put in the markers ? I need to replace both front and back A=and looking for opinions on which bulbs to use. If I go to led which ones do I order ?
jdamato1 is offline
post #7 of 7 (permalink) Old 03-26-2010, 10:05 PM
The fronts are 1157's and the rear are 1156's... The LED replacement bulbs have mixed reviews... they aren't as great as they sound...
Tags
signal , turn signal , wiring
