Regulator Question, need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 03-24-2006, 04:43 PM Thread Starter
Hey, does the regulator need to be grounded or does the plug already take care of that? Basically, do I need to attach it to a metal spot, or can it be attached to anything?
I hope I get an answer quickly, as thats the last (keepin my fingers crossed) thing I have to do to get the bike running after my stator replacement.
Ben
InsuredDisaster is offline
post #2 of 13 (permalink) Old 03-25-2006, 08:37 AM
jm1515's Avatar
Ben
No xtra ground needed...it's grounded via the harness.
If convenient, an xtra gound lead from the mounting screws wouldn't hurt, tho....
john m
Somewhere deep in OH....
jm1515 is offline
post #3 of 13 (permalink) Old 03-25-2006, 11:36 AM Thread Starter
Hey,thanks. Righnow,I sortahave a temporary location for it, but later I'll be redoing it with a real metal bracket properly.
Ben
post #4 of 13 (permalink) Old 01-07-2007, 12:09 PM
Old Skool Metal Head
Bucky's Avatar
Ok i know im new here, but i have a R/R question also.
The three yellow wires, does it matter which of the three yellow wires on the harness they connect to?
And also, is the signal wire from the ignition switch/junction box, a smaller guage wire than the others on an OEM harness?
Bucky is offline
post #5 of 13 (permalink) Old 01-07-2007, 05:36 PM
I'm just getting ready to do stator & R/R replacing myself.
Not too sure on the wire sizes, but the 3 yellow wires should be interchangable.
post #6 of 13 (permalink) Old 01-07-2007, 06:17 PM
Uber Member
wire size seems to be 12-14 gauge stranded. I went with 10 gauge stranded 200c teflon. though its stiffer, it will do better with the heat, and chemical resistance that seems to plague these wires. All 3 wires are interchangeable, make sure you get a good splice, each wire needs to be able to run about 10 amps peak, and if you get a bad slice done, it will fry it. i suggest doing a wire splice, solder it, and use a polyeflin shrink on it...
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #7 of 13 (permalink) Old 01-30-2007, 05:04 PM
fergy's Avatar
Mine's not grounded after the relocation. Been fine since.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 13 (permalink) Old 01-30-2007, 08:14 PM
93VN750's Avatar
All the parts inside the r/r are electrically isolated from the case, no electrical ground is needed.
However, a good heatsink to mount it on sure wouldn't hurt.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #9 of 13 (permalink) Old 01-31-2007, 10:44 AM
darrelc5's Avatar
I relocated my rectifier/regulator after replacing the stator and it didn't need grounded other than the harness ground wire.
I intended to replace the wires from the stator leads into the R/R plug, but couldn't find the fastin female connectors to install into the harness connector housing at the R/R. Does anyone know where to get these? They are crimp-on, but have a spring retaining barb in the back to hold them in the housing.
I know that, if I replace these wires, it is necessary to slice into the headlight relay with one leg of the alternator (one yellow wire) because the alternator voltage pulls the relay in. After being engaged by the alternator, the ignition circuit latches the headlight relay on.
I fused my stator leads where they connect to the harness. As discussed elsewhere on the site, I also found it necessary to use 15 Amp fuses. The 10 Amp fuses popped in about a minute.
Pictures here: Yahoo Photo Album: Fused Stator
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #10 of 13 (permalink) Old 01-31-2007, 03:15 PM
Uber Member
do you have an aftermarket stator? the stock stator should be fine with 10 amp... if you have an aftermarket, then i can see where the 15 amp would be needed...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
