Headlight Trouble - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 20 (permalink) Old 03-16-2010, 01:57 AM
I didn't know the Vulcan ever had them. I'm sure glad mine doesn't. If it had, they would have been redesigned right away. I had a Yamaha Virago 750 that had them and what a nightmare. Either they would turn off before you got to the turn, or they would keep flashing long after you made the turn. I finally rigged them so they worked as normal turn signals. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #12 of 20 (permalink) Old 03-16-2010, 02:47 AM
sounds like a bad connection inside the Reserve Lighting Unit, or a sticking Headlight relay inside the Junction Box. Next time you don't have headlights, check that the blue wires in the JB have power. If no power present then its the JB, if there is power then its the RLU.
Slim, IIRC you can take one of those blue wires and pull it off a connector and plug it onto an empty connector next to it that is powered when ever the key is on. It can get your lights back on quickly to get you back home in the dark. Sorry, I just don`t remember the specific wire or connector.
I am sure you know this and can spell out the particular wire and connector location to try this solution.
post #13 of 20 (permalink) Old 03-16-2010, 03:30 AM
yes you just move the blue wire into the empty slot... doesn't matter which one, they both o to the headlight eventually. but then you bypass the relay and can cook the wire harness if something should fail...hmm wonder how I know this one...
post #14 of 20 (permalink) Old 03-16-2010, 04:12 AM
The Professor
lance328's Avatar
Bypassing the HL relay will not possibly "fry" your harness since it is still a fused circuit. The only difference is the HL will come on as soon as you turn your key.
If you decide to alter your wire harness for aftermarket electrical devices and don't do your haome work then 'YES" you can fry the harness. It's usually something stipid like one copper strand hits a ground or you use a fuse that's larger than the "load" the system was designed for.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #15 of 20 (permalink) Old 03-16-2010, 07:18 PM
well my harness is shot... and the only thing i did to it was add an aftermarket headlight, and bypass the relay... to wire in the new headlight, i ran a wire streight from the spare slot on the JB to the headlight, and grounded the headlight out through the OEM ground wire.
post #16 of 20 (permalink) Old 03-17-2010, 02:37 AM
Chavisimo's Avatar
Hey slim. I moved the blue wire on the JB to the empty slot when I got my bike last year. Previous owner put a switch on there but then the highbeams would not work. When I moved the blue wire to the empty slot, headlights worked fine. As Lance said, the only difference I can see if that the headlights turn on when the key is in the on position. I just keep my battery charged well and she cranks up every time without issues.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #17 of 20 (permalink) Old 03-22-2010, 06:40 PM Thread Starter
Seminole's Avatar
So i went out and bought a new (to me at least) junction box thinking that this is the problem and I installed it today. The headlight is still not working so I am thinking that it must be the reserve headlight unit. With the new junction box all the lights work, blinkers blink but the headlight is still not working. The lights on the dash do not show up for the headlight and when I flip the high beams on that light does not come on as well. Would this be the reserve headlight unit not letting it work or is it something else? I do not own a multi-meter so I am thinking that I might have to go out and buy one to track down this problem. Sorry I am so amateur at this I do like learning about all these things at least.
One other thing, How do you take the wires out of the plastic around them at the junction box? I was hoping I could just switch the blue wire with the empty spot to at least have a headlight till i get this problem sorted out. I have tried pushing the wire out with a flat head but no luck, I am afraid I will bugger up the connection if I mess with it to much.
Jason Mercer
Tallahassee FL
1991 Vulcan
Seminole is offline
post #18 of 20 (permalink) Old 03-22-2010, 07:21 PM
DO you have a test light?
post #19 of 20 (permalink) Old 03-23-2010, 07:35 AM Thread Starter
Seminole's Avatar
no test light as well, Its something on the things to get when in home depot but just somehow forget about it.
Jason Mercer
Tallahassee FL
1991 Vulcan
Seminole is offline
post #20 of 20 (permalink) Old 03-23-2010, 03:34 PM
Get a test light at Wal mart, you can even get a decent Multi Meter for cheap at Wal-Mart. but in order to help you fix your bike, you need to have the proper tools.
Every one needs to own a Test Light at a bare minimum for testing electrical problems. A test light has about a thousand different uses depending upon what you are testing and how you hook it up for testing. A Multimeter is also a good thing to have, but make sure you get a digital one instead of analog. But until you get the right tools, its going to be hard for us to help you figure out what is going on.
Tags
battery , fuse , headlight
