Headlight Removal, How ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-21-2006, 03:01 PM Thread Starter
O.K., I wanted to post this some time back, but I have to ask now.
Several months ago, I had to drive my stepson's VN750 several miles
to my garage. The dang headlight was pointing so low, I couldn't believe
he never complained about it. He must have been driving with psychic
sensory. Anyhow, I loosened the 2 bolts on each side of the headlight.
They were stubborn, but I loosened them. I moved the bike back 17 feet
from my garage door and aimed the light to a mark 2" below the height of
the headlight on the bike itself. Perfect. Now I try to tighten the bolts.
They won't ?? They get kind of tight, but something inside is turning
along with my tightening.
It looks like I have to get inside the headlight to find out why. I take out
the 2 screws on each lower side of the headlight. The headlight won't
come out? I look for a screw at the top, where I am getting resistance,
but there is only smooth chrome? So I pull harder. Whoh, something is
going to break. I pull down & forward. I push up and pull forward. The
dang headlight ain't coming out! Before I break something, I stop. I inform
my stepson he'll have to adjust it as he drives because I can't tighten the
2 bolts on the side.
Yesterday he stopped by. I looked at the headlight. There is NO bolt in
the right side of the bike now, but the other bolt seams to be holding fine.
My question: How do you remove the ^&*$&*)# headlight ???
VN750A is offline
post #2 of 4 (permalink) Old 03-21-2006, 03:14 PM
Uber Member
LMFAO i had the same problem. i know its a pain in the a$$ but your gonna have to turn the front part of the housing clockwise to about the 2'oclock position then it comes of with a lil more love.....going on is easy if its any consilation to ya...
yes there are 2 nuts on the inside that are turning....i was thinking bout maybe gluing them in place or something cause it is a pain. good luck and be carefull
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 4 (permalink) Old 03-21-2006, 04:13 PM
"ya can't live forever"
artman's Avatar
Dude !! After you remove the two screws on the chrome retaining ring there
is a little tab at the top of it that must be swung down. What I mean is to take hold of the ring at the bottom and gently pull it forward then the tab should rock free. Those two other chrome bolts on the mounting bracket really shouldn't be removed and they really don't get super tight. They are there just for aiming the head light. Also don't mess with the left - right adjusting screw if you can help it.
artman is offline
post #4 of 4 (permalink) Old 03-21-2006, 04:19 PM Thread Starter
I knew it would be something easy like that.
Thanks !
VN750A is offline
