Dead short somewhere - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 01-22-2010, 08:15 PM Thread Starter
The bike has not been used since before Christmas and it ran fine all last year. I came to start it and there's a dead short somewhere. When a put a meter across the battery it shows 13 volts. Turn on the ignition and the voltage drops to almost zero. Attached to the Battery live cable at the starter relay as a feed wire in white and red. If I disconnect this, the short disappears. My question is....where does the white and red feed wire go to and why would it short for no apparent reason?
Thanks
John UK
johnnybaby is offline
post #2 of 16 (permalink) Old 01-22-2010, 08:21 PM
The Professor
lance328's Avatar
Thanks
John UK
That wire goes to the junction box and then to the regulator/rectifier. That wire feeds the junction box and when the bike is running it charges the battery. Check the back side of the junction box and R/R connector for acid damage from the battery.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 16 (permalink) Old 01-22-2010, 08:27 PM Thread Starter
Thanks for quick reply. I'll try it in the morning.
John
post #4 of 16 (permalink) Old 01-23-2010, 06:14 PM Thread Starter
Dead short found
I think I've found the dead short. The fuse box has a short through the main fuse. Remove the fuse, no short. I'm going to bypass the fuse and fit an inline one.
John UK
post #5 of 16 (permalink) Old 01-23-2010, 11:01 PM
I thik your short is beofre the fuse... which means it is external from the JB
but if you suspect the JB... I can repair it. send me a pm for more info...
post #6 of 16 (permalink) Old 01-24-2010, 03:27 AM
If removing the main fuse eliminates the short, I suspect that you actually have a bad battery, because a healthy battery has no problem blowing the fuse.
With a good battery you get heavy sparking when you connect/disconnect it, if something is shorted.
pappa is offline
post #7 of 16 (permalink) Old 01-24-2010, 10:23 AM
Search Goddess
Dianna's Avatar
I would agree with the battery. I thought I had a dead short, battery would be fine, start the bike and dead! What it turned out to be was the battery. Eventually it would not even take a charge and here's why. The battery was fine when cold, but once it started warming up there was a seperation in the plates/elements. Battery eventested fine for initial load, but the mechanic went on to explain that AGM batteries do not like to be drained down to zero will develop a bad spot, so your dead short is actually IN the battery.
Never heard of it before but decided to replace the battery anyway (Start with the simple stuff first). New battery, new life and no more dead short!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 16 (permalink) Old 01-24-2010, 12:58 PM
Actually this is quite common in colder climates, with conventional batteries... I used to see it a lot when i worked for NAPA. I still see it occasionaly on the military batteries as well.
post #9 of 16 (permalink) Old 01-24-2010, 04:31 PM Thread Starter
Dead short
Thanks for all the replies. I'll try the battery route. Must admit I wasn't thinking in that direction, I always seem to suspect the complicated things!
I'll let you know how I get on.
John
post #10 of 16 (permalink) Old 01-25-2010, 12:58 AM
I agree it almost has to be the battery. First of all, a dead short would immediately burn out the fuse, and if someone were dumb enough to replace the fuse with something solid, or bypass the fuse, it would burn up most of the wiring on the bike. I learned about the importance of fuses the hard way a long time ago, when as a teenager, I fried almost all the wiring on a '63 Chevy II after causing a short with no fuse. It took me weeks to rewire everything. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
