Cleaning the R/R? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 01-01-2010, 04:34 PM Thread Starter
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
Cleaning the R/R?
Hello again.
I pulled the R/R last night and was planning to do the relocation today, but after I pulled it off, my OCD kicked in and I have this overwhelming urge to clean it! Is this possible? Will it hurt the thing if I spray it down with some Simple Green and wipe it real well with a rag? I know it won't be in new condition but it would be a little cleaner at least!
As always, thanks for the input and guidance.
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #2 of 21 (permalink) Old 01-01-2010, 08:28 PM
go for it... get as much as the crud off as you can.. a wire brush might help too
post #3 of 21 (permalink) Old 01-02-2010, 03:16 AM
dirtrack650's Avatar
Or tooth brush. Some have relocated and painted too.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 21 (permalink) Old 01-02-2010, 03:48 AM
Yeah, it's waterproof, won't hurt anything. I also have OCD (and love it), so I understand the need to do things right. I just hate it when somebody does a halfway job, even when it works. No satisfaction in it. Unfortunately, due to being shorthanded and not having enough money to buy what we need, I have to do a lot of that at work. It's "get it fixed and get it out, there is something else already overdue". Glad I don't have to work on my own stuff like that.
BTW, I'd be careful how you wire it when you relocate it, make sure you use wire at least the same size as the original if you have to splice any new wire in. The last thing you want to do is create any extra resistance in the wires. I decided to leave mine alone, and have managed to put over 125,000 miles on 2 Vulcan 750s without any electrical problems. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 21 (permalink) Old 01-02-2010, 04:14 AM
cm4cm5's Avatar
im planning on doing mine soon also, and if i remember right, if we relocate to the left side (as we sit on bike) in front of passenger peg. the stock wires wont need to be extended. this is correct right?
and if its painted, it should be a fairly thin coat. so it can cool properly. is this correct also?
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #6 of 21 (permalink) Old 01-02-2010, 09:49 AM
While cleaning the R/R check the connector on the harness.
I'm cleaning and relocating the R/R on my '86 and I'm worried about corrosion at the electrical connection.
We also need to clean where it can't be seen.
How can we clean the metal contacts without harming the plastic plug?
Mo
moloprintz is offline
post #7 of 21 (permalink) Old 01-02-2010, 10:16 AM
Search Goddess
Dianna's Avatar
The stock wires will extend just fine for the relocation. It helps keeping the connection clean if you mount it with the plug pointed down (so nothing accumulates).
As far as paint.. I never felt the need. Think of it this way, would you put a blanket around a radiant heater? The R/R actually blends in very well at the new location without being fancied up *L*
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 21 (permalink) Old 01-02-2010, 12:09 PM
Jesus-Family-Coffee-Bike
Originally Posted by VN750Rider/Jerry View Post
...I also have OCD (and love it), so I understand the need to do things right. I just hate it when somebody does a halfway job, even when it works...
Funny that the consensus is that people who want to do things well are Obsessive Compulsive (btw, I am definitely OCD!)
http://photobucket.com/webby778_bike_pics
old bike:
93 vn750 - Gray/Navy - Mac Staggered Dual Tapered Tips Exhaust - DEI exhaust wrap - K&N air filters - ACCT rebuild - Deka ETX15L MF battery.
current bike:
95 vs800 - Tan/Maroon custom - Cobra pipes - Jardine seats - stage 1 jet kit, carbs re-tuned - 21' front wheel - crash bars with pegs - Willie & Max saddlebags
webby778 is offline
post #9 of 21 (permalink) Old 01-07-2010, 08:54 AM
The Professor
lance328's Avatar
OCD is a term made up by lazy people, it used to be you were called a "Hard Worker". Since alot of people have no idea what hard work is or too lazy to do it. So when they see someone working hard it's easier for them to justify being lazy and say that person has a Disorder (OCD)
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 21 (permalink) Old 01-07-2010, 09:19 AM Thread Starter
I can agree with the "lazy people" philosophy as the term gets abused these days, but I truly am OCD. There are certain things that have to be done like i always have to open and close exterior doors 3 times or flip a light switch twice... and everything else has to be done thoroughly and properly.
I do have a strong work ethic being self employed, but doing a job completely and doing it well is something that I pride myself on. I do not, however, enjoy how I toiled over this R/R with simple green, CLR, and a wire brush to get the dirt and rust off of it (although I am elated with the results).
Phil aka Art
"Vanessa"
26,440 miles
V&H Cruisers
Ear Shave
Rejet carbs
R/R relocate
HD Heritage seat
12" ape hangers
To Do:
Mirrors
