Great Looking Voltmeter! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 65 (permalink) Old 12-11-2009, 03:59 PM Thread Starter
ExNewbie..Still Learnin'!
rsawyer's Avatar
Thumbs up Great Looking Voltmeter!
Recently picked up a voltmeter and mounting cup off E-Bay.
Been looking for a while but this is the closest to an OEM look for our gauges that I've seen. Auto Meter 2592. 2-1/16" , 8-18V. Even comes with a green cover for the lightbulb to match the lighting. Paid $30 + shipping
The pedestal mounting cup is chrome-plated plastic but looks sharp. Auto Meter 2203. Paid $28 shipped.
Have not installed yet, but thought I'd share the info and see if anyone else is satisfied with the look/performance.
See attached photos.
Name:	Auto Meter 2592 Voltmeter.jpg
ID:	2464   Click image for larger version
Name:	Auto Meter 2203 Cup Mount.jpg
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #2 of 65 (permalink) Old 12-11-2009, 05:03 PM
When I mounted mine I put a little silicon underneath to stop any water from getting down into the bikes housing. One single screw holding it down. I have no complaints.
I painted the facia trim to match my guages.
post #3 of 65 (permalink) Old 12-11-2009, 07:18 PM
electrum's Avatar
very nice look... i've been considering a voltmeter and i think you found the one i will get... thanks for the info!
96 Vulcan 750
electrum is offline
post #4 of 65 (permalink) Old 12-12-2009, 09:31 AM
93VN750's Avatar
That's a very nice set up there.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 65 (permalink) Old 12-12-2009, 04:47 PM
VN750_DawgsFan's Avatar
Picked up my volt gauge cheap through tractorsupply.com, bought the mount at Pepboys and Lance made the cup. THANKS LANCE! He wired it up through the headlight bucket. Works great.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #6 of 65 (permalink) Old 12-12-2009, 07:19 PM
Send a message via AIM to Acid7711
Same thing I put on,
Except my buddy pretty much runs Autometer world headquarters here in Sycamore, IL. He specially waterproofed mine for me
Acid7711 is offline
post #7 of 65 (permalink) Old 12-13-2009, 12:30 PM
cglennon's Avatar
I used an older voltmeter (just liked the color coding on the gauge face) and ran into one issue; the needle would stick in warm weather. I'm pretty sure that the inner workings of the meter are old mechanical style and the cup (made for the gauge by the same manufacturer) was 'pinching' the gauge housing a little too much. I kept moving the cup retaining ring back little by little to find a sweet spot. I'm not sure if this would happen to a newer gauge which probably has electronic inner workings. Anyone else run into this with a newer analog gauge?
Chris Glennon - Portland, OR
cglennon is online now
post #8 of 65 (permalink) Old 12-13-2009, 01:06 PM
Columbus, Ohio
jimkonst's Avatar
That looks a lot better than I thought it would. I just bought the Kuryakin LED gauge, but haven't installed it, yet. Now I wonder if I should swap it for one like yours.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #9 of 65 (permalink) Old 12-13-2009, 01:20 PM
Where did you hook up the wires to Battery, junction box? and how did you get the light to work? but it looks very sharp
dre82s is offline
post #10 of 65 (permalink) Old 12-13-2009, 11:28 PM
cglennon's Avatar
Don't give up on the Kuryakin LED gauge. I've seen it highly recommended on this forum for function, ease of installation and accuracy. I just like the analog look better to match the existing gauges, a personal preference.
