1156 led board for a $ - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 12-03-2009, 10:29 PM Thread Starter
dirtrack650's Avatar
Thumbs up 1156 led board for a $BUCK$
This just came in the mail from ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320456770654
I installed one in the rear blinker and was very impressed with the brightness, quality, and quick service from the seller. Fit right in, no mods required.
It has my VN750 approval to recommend to you all..
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 18 (permalink) Old 12-03-2009, 11:37 PM
Jace Bror's Avatar
I would love to see how this worked out. what colour, I musta missed it in the ebay listin
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #3 of 18 (permalink) Old 12-04-2009, 01:07 AM
dammit and im wasting my time building one from scratch.
bollacks. well it'll be an adventure.
6204 is offline
post #4 of 18 (permalink) Old 12-04-2009, 05:39 AM
Headbanger/Popes of Hell
ruger's Avatar
we need pic's!!!!!! I'd buy that for a buck.
ruger is online now
post #5 of 18 (permalink) Old 12-04-2009, 08:08 AM
Crobins365's Avatar
DT, I'm assuming that with all the LEDs, there's enough resistance so that the turn signal unit recognizes there's "a working bulb" in there and so functions properly? That's always a problem with just replacing the bulb with an LED cluster.
C
Crobins365 is offline
post #6 of 18 (permalink) Old 12-04-2009, 08:29 AM Thread Starter
WHITE. But know led white has more blue in it than a filament bulb.
It did increase the flash speed, but not to the point of hyper flashing as some call it. I'm going to order a couple more.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #7 of 18 (permalink) Old 12-04-2009, 09:04 AM
I would think the faster flash could be a good thing. Get you more attention.
post #8 of 18 (permalink) Old 12-04-2009, 10:05 AM
cglennon's Avatar
The opposite it true. LEDs do not draw enough current to satisfy most thermal based flasher units, which use bulb current draw to determine blink rate (no current = fast blink). In the early days of LEDs folks would add all kinds of resistors to the circuit to compensate, but defeats the purpose of using LEDs (low power consumption) in the first place.
Bottom line: the stock thermal flasher has to be replaced with a no-load electronic version (about $12+) for LED blinkers (and normal blink rate) or live with the faster "bulb out" blink rate (NOTE: DOT blink rate standards are 60-120/minute. I'm not sure if the "bulb out" blink rate is faster than 120/minute, but it is annoyingly fast).
Chris Glennon - Portland, OR
cglennon is offline
post #9 of 18 (permalink) Old 12-04-2009, 10:56 AM
letitflight's Avatar
this is pretty cool except for the shipping
what if we (whomever wants some) order a 'bulk' the seller, we might get a good discount on the shipping. I believe lots of us would want to order a set.
just my 2 cents.
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #10 of 18 (permalink) Old 12-04-2009, 12:33 PM Thread Starter
Originally Posted by cglennon View Post
Bottom line: the stock thermal flasher has to be replaced with a no-load electronic version (about $12+) for LED blinkers (and normal blink rate) or live with the faster "bulb out" blink rate.
My front blinkers -1157 bulbs- are stock so I'm not getting the 'bulb out' blink rate. I'm going to order some 1157 LEDs to test w/electronic flasher in the future.
There is one drawback to any LED board: side visibility is reduced compared to filament bulbs. Our amber lenses are not designed for LED's directional lighting. I'm installing side LED blinkers (nothing more than an amber LED running light) on my bags to assist in visibility.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
Tags
blinker , led
