fan relay? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-29-2009, 10:11 PM Thread Starter
1995 750 vulcan
w.ben14's Avatar
fan relay?
my wiring diagram shows the fan relay in the junction box....is this right?thats the box behind the battery, correct?
my fan does not come on, and wont come on if i ground the lead from the temp switch..........any ideas?
w.ben14 is offline
post #2 of 5 (permalink) Old 11-29-2009, 10:26 PM
hook up the leads on the fan, there is a plug,to an external 12 volt battery and see if the fan runs if it does it is the relay or wiring ,if not the fan is shot
post #3 of 5 (permalink) Old 11-29-2009, 11:07 PM Thread Starter
1995 750 vulcan
w.ben14's Avatar
i will test the fan tomorrow, if its the relay i think i will wire up my own circuit independent of the JB, i assume a standard 12 v auto relay will work fine...i'll certainly fuse it, and maybe an emergency override switch.
bad idea?
w.ben14 is offline
post #4 of 5 (permalink) Old 11-30-2009, 01:39 AM
I have considered the same setup. I really don't see a problem with it,go for it.
post #5 of 5 (permalink) Old 12-15-2009, 01:10 PM
your idea will work fine
