Ignition problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-29-2009, 01:08 PM Thread Starter
Ignition problem
Hi! Its Aleksi from Finland.
I was checking my mothers bike chain tensioner. I wanted to know how it looks. I take the tensioner off, and put it back. I didn`t rotate engine or anything else when the tensioner was off. But when I tried to fire up the engine it didn`t start. Then I checked the ignition, and it was all wrong. Sometimes you get spark sometimes not. Then I tried with old broken ingnition box and it did the same thing. So is it possible that I ****ed up chain timing or there is a broken igniter? Is there any easy way to test ingniter? Any other helps?
alluz is offline
post #2 of 6 (permalink) Old 11-29-2009, 03:02 PM
Tervetuloa Aleksi.
If the bike worked fine before, it is probably something you did. Even if the timing is wrong, there should be a constant spark -unless your battery is already too weak from trying to start. Recharge the battery. You could also hook up a car battery, if that is an option for you.
I am sure more knowledgeable people will tell you soon if it is possible to mess up the timing by just removing the tensioner.
pappa is offline
post #3 of 6 (permalink) Old 11-29-2009, 07:27 PM
Calif Rider
weh44att's Avatar
No just removing the cam chain tentioner and then reinstalling it will not affect the timing. It sound more like you now have a ignition problem. You may have to check all of your connections,first start with the battery. A lose connection on the battery can easily cause all your problems, or a dirty one.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 6 (permalink) Old 11-30-2009, 02:38 AM
Simple Solutions
seebeeare's Avatar
out of time no but our cam chain tensioners have a spring and unlesss u retract them before/during install they will remain way to tight causeing way to much strain on you cam chains ... grambos trick / a small screwdriver in the acct to retract the plunger hold and bolt into place release plunger and aply 1/4 to half turn more tension onto chain....
do u have spark at the plug?
check coil voltage...
check all connections and grounds ..
a weak battt will spin the engine and not leave enough voltage for spark ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #5 of 6 (permalink) Old 11-30-2009, 08:44 AM Thread Starter
Yeah, I have tried with car battery and it wont start. That damn igniter costs in europe 650 euros, which I think is nearly 950$. Is there any way to check that igniter box?
Btw, some pics of the bike in my album.
alluz is offline
post #6 of 6 (permalink) Old 11-30-2009, 01:53 PM
During the time I have been reading this forum, there have been very few igniter failures, if any. If you don't already have the service manual, download it - see seebeeare's signature. It has a table in the electrical section for checking the resistances between the igniter pins.
If you decide to by a new (used) igniter, there are some for less than 100EUR on http://www.ebay.de and http://www.bike-teile.de
pappa is offline
