Reserve lighting unit - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 11-23-2009, 03:26 PM Thread Starter
Hello, everyone.
Just bouught a used '04 with about 15k miles, in a good overall condition. Fixed the cam chain tensioners and regulator/rectifier unit. While doing so, I noticed the reserve lighting unit is missing, i.e. not installed at all. The 6 contact connector from the bike wiring harness is simply hanging freely. In addition, there is a wire (blue/yellow) leaving from this connector which is cut. I stripped the harness further up, trying to find the other end of it, with no success. I can't find the continuation of this wire, yet the harness seems to be untouched.
Page 15-36 of the service manual claims this blue/yellow wire supposedly goes to the dimmer switch. But the dimmer switch is up front by the headlight and I can't see any cut wire on the harness. I found wires with the same color leaving from the fuse box, but they turn towards the front of the bike, never reaching the lighting unit. I assume the bike electrical system was modified. Any clues, please?
rct2000 is offline
post #2 of 2 (permalink) Old 11-26-2009, 01:43 PM
For starters..
Does your headlight gome on when you switch on the ignition or only after you have started the engine?
Disconnect the fuse box (a.k.a junction box) 8-pin connector and the headlight bulb. Is there continuity from the blue wire of the 8-pin connector to the R/BK or R/Y wire of the headlight connector?
These tests should tell us if the headlight relay is bypassed and if the headlight is still powered from from the headlight fuse.
I found wires with the same color leaving from the fuse box.
There should be no blue/yellow wires going to the junction box (as far as I can see from the wiring diagram).
pappa is offline
