Starting problem!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 11-17-2009, 05:20 AM Thread Starter
fartin'martin's Avatar
Greetings one'n'all
Having done all the work to 'Sweep' to bring up to a decent standard, another fault has reared it's ugly head.
When I stopped to cross the ferry the other day, as I was waved on I lept on the bike, turned on the ignition and pressed the starter. It turned over once, then totally died. No electrics, nothing. (not the same nothing that's on another thread at the moment).
As I have changed stator, R/R, leads, iridiums, MF battery, I'm guessing ignition swich.
Any input greatly appreciated
Ride free, stay safe
Regards to all,
Martin
'88 FJ1200 3CV
1986 VN750 A2 (now sold to another old fart!)
Jardine fishtail pipes (de-goated)
Stator No 2
Avon Venom AM41/42 tyres
Sundance grips
etc
etc
fartin'martin is offline
post #2 of 19 (permalink) Old 11-17-2009, 05:45 AM
The Professor
lance328's Avatar
Originally Posted by fartin'martin View Post
Greetings one'n'all
Check your battery to frame ground, make sure it's clean and tight. Check the main fuse, if all else fails disassemble the ignition switch and clean the contacts.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 19 (permalink) Old 11-17-2009, 06:26 AM
Simple Solutions
seebeeare's Avatar
x2 to wut lance says
double check all connections pos and neg
im leaning towards ig switch as well ...
is the bike still there ? or did u manage to get her home?
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 19 (permalink) Old 11-17-2009, 10:01 AM Thread Starter
Hi Lance & See,
I've checked all the fuses and they seem OK. The all earth grounds were re-done whilst I had the engine out of the frame, but I'll double check them anyway. The slide on the key part of the ignition switch has been stuck open since I got it, so I'll take your advice and strip it out at the weekend.
As for getting the bike back, I was on the way to pick up a hire truck so that we (my missus) and me could move house. So I had to push it onto the ferry, push it off again on the other side before I remembered that I had breakdown cover! What they call a senior moment. 1 quick phone call to a very nice lady in a call centre in Bangladesh or somewhere, and I was picked up and taken home! Well worth a fiver a month!
Thanks once again for your help
Regards to all,
Martin
'88 FJ1200 3CV
Stator No 2
Sundance grips
etc
etc
post #5 of 19 (permalink) Old 11-17-2009, 11:59 AM
I've had trouble with the kill switch on my 87.
hydrodog is offline
post #6 of 19 (permalink) Old 11-17-2009, 12:03 PM
letitflight's Avatar
you might need to check the lil switch on the clutch lever.....i have to slightly touch my lever ever now and then to start the bike....
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #7 of 19 (permalink) Old 11-17-2009, 03:08 PM
Simple Solutions
seebeeare's Avatar
Hi Lance & See,
check grounds with a light ... and double check connections into the JBOX dont want to go there but as a last resort it could be that ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 19 (permalink) Old 11-20-2009, 03:06 PM Thread Starter
Greetings one'n'all
Stripped the ignition switch, checked all earth grounds, junction box etc, etc. Finally tried a straight wire jump between battery positive & the starter motor, working on the principle that it would prove that at least the starter motor was OK. And got nothing. So before I started hitting it with a large metal bar I thought I'd just connect the car up to it with jump leads, and guess what! All was OK. The battery was flat!!!
So I did a continuity test on the stator and it failed!!! I only fitted the bloody thing six weeks ago!!! After all the work I've done on it I'm beginning the think that perhaps my old Triumph Sprint wasn't so bad after all.
Now where did I put that trolley jack.....................
Regards to all,
Martin
'88 FJ1200 3CV
Stator No 2
Sundance grips
etc
etc
post #9 of 19 (permalink) Old 11-20-2009, 03:30 PM
Simple Solutions
seebeeare's Avatar
Greetings one'n'all
yay im not thr only one with three stators yay ... sorry bout the luck check the RR and dont bye a cheap stator ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #10 of 19 (permalink) Old 11-25-2009, 03:46 PM
VSB
Frick! That sucks man.. I feel your pain... literally. I'm having the same electrical problem.
Every morning I have to charge up the battery for one hour before the bike will even consider starting. My starter will turn over A-ok on a low battery but there is not enough juice to fire the ignition coils AND make the starter turn over. So all I get is the starter turning over the engine, and no spark. freakin sucks.
Do you guys think it is the voltage regulator/rectifier that is bad?
I cleaned all the battery cable ends with a wire brush and reconnected them tightly. The battery gets killed by this bike very 6 months due to the electrical problem. So it is pointless to go buy yet another new battery until the problem is solved.
How do you test the stator on these bikes? I own a digital ohm meter... what readings should I get between the lead wires from the stator with stator unplugged ?
I also noticed the clutch switch doesn't work well on my bike. If the bike is in gear and clutch pulled in the engine won't start. It will turn the starter motor.
note; I found a new K&L brand voltage r/r from J&P cycles for $120. but i have not purchased one yet. they also sell ElectroSports brand stators for $120 for our bikes. I just wanted to pass that info along so nobody spends hundreds more at the stealership. J&P's # 1-800-397-4844
VSB is offline
