I'm going to buy these and give you a report - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 11-09-2009, 07:57 PM Thread Starter
dirtrack650's Avatar
We all know we need to save amps and watts on our charging system when adding spots or other lights. Some have added 20 or 30 watt spots with good success not overloading the stator or r/r. I'm going to order these and let you all know with pics and impressions if they are worth the money.
H3 LEDS
Time line will be a few weeks. I'll be installing in a clear lens spot.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 11 (permalink) Old 11-09-2009, 10:39 PM
Love My Baby
rubyrick's Avatar
Look BRIGHT! I'm looking forward to your report. Might want to add them to my baby if your power consumption is minimal and your lumination meats your expectations.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #3 of 11 (permalink) Old 11-09-2009, 11:37 PM Thread Starter
Power usage is only 1 watt. Bought them tonight on a buy it now for $6.99 with free S&H. Hope they aren't crap but at least it's not a lot of money. Will post on this thread asap.
This is what I ordered. Most likely, you get what you pay for so I'm not expecting much...
eBay SMD LED H3
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #4 of 11 (permalink) Old 11-10-2009, 07:56 AM
Redneck on a rice burner
Wileysden's Avatar
Location: American by birth,Southern by the grace of God ..,.AMEN !
I have these in my spotlights.They have a blueish tint to them when there on.I like them.
Wileysden is offline
post #5 of 11 (permalink) Old 11-10-2009, 09:56 AM
Vulcan Traitor ;)
Send a message via Yahoo to Keemez
I also got some real similar to these. The "bulbs" are not as bright as you'd think they are- they need a lot of help from the reflective surfaces in whatever housing they go into. They certainly do not create a concentrated beam of light like regular filament type bulbs do. They'll increase your visibility factor for oncoming folks but I wouldn't expect much additional forward lighting for the (motor) driver. I never got around to mounting mine because I made the decision to sell before starting the install process. I'll just put the lights on whatever I get to replace the Vulcan.
Keemez is offline
post #6 of 11 (permalink) Old 11-10-2009, 06:04 PM Thread Starter
Keemez - Great reply thanks. My intentions are to increase the 'visibility factor' like you say. I am anxious for LED's to improve to be used as true headlamps/driving lights.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #7 of 11 (permalink) Old 11-11-2009, 08:51 AM
Vulcan Traitor ;)
You betcha. LEDs as commonplace lighting devices is not long off- there was a writeup about this subject in a recent issue of Car&Driver. Audi is experimenting with the technology some. As the cost of manufacturing high power LEDs decreases, we can expect to see more and more out there. I'm all for it.
Keemez is offline
post #8 of 11 (permalink) Old 11-21-2009, 03:40 AM
arc06's Avatar
I bought a set of 3 watt luxeon bulbs for my taillight. they r blinding. and why wait on led headlights. go HID. they r extremely bright and fairly low maintanence
arc06 is offline
post #9 of 11 (permalink) Old 11-21-2009, 09:14 AM Thread Starter
Where did you find the 3 watt bulbs? I'm building a 750 spectre bobber and would like everything but the headlight to be LED.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #10 of 11 (permalink) Old 11-21-2009, 02:13 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Arc - Do you have purchase/installation specifics/pics on both the 3W tail-lightbulbs and the HID headlight conversion?
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
Tags
led h3
