Need to check connections- Where to start? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-09-2009, 02:17 PM Thread Starter
DblAA's Avatar
My taillight and license plate light sometimes do not illuminate when I start the bike, yet the head lamp and all other electronics do. Other times it lights up normally as expected. I am assuming there is a loose connection there somewhere, but where do I start the process of finding the problem? I've never messed with anything electrical on the bike yet (aside from replacing the battery.)...TIA
DblAA is offline
post #2 of 5 (permalink) Old 11-09-2009, 02:22 PM
KIMMERLING's Avatar
My guess would be to take off the seat and make sure the connectors going to the rear lights are clean and connected/not pinched or worn through. Just a guess.
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #3 of 5 (permalink) Old 11-09-2009, 04:01 PM
Simple Solutions
seebeeare's Avatar
a test light or volt meter would be your best bet flollow the wires from the light back to the fuse box ... there is a servise manual in my sig and im sure u can find a wireing diagram that will identify the wires in the harness... check both positive and negitive side of the circuit ... i think the best way is with a light and just come back one connection at a time cleaning and dielectric greasing it all the way back ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 5 (permalink) Old 11-09-2009, 05:25 PM
I will agree with the 2 posts above. Finding electrical gremlins is not my favorite activity, but maybe I can give you a couple of specifics from the Clymer manual wiring diagram.
The tail/brake light housing has a connector with a B/Y (Black/ with a Yellow stripe) ground wire, a L (Blue) wire for brake light ( I think?), and a R (Red) wire for taillights.
The license plate light has 2 separate single connectors that are spliced into the harness just before the tail/brake light connector. One is the B/Y ground wire, the other is Red. I believe the red must be for taillights and license plate because they both fail at the same time. I think it is likely that the loose connection is on the red wire at the ignition switch at the front, as it is direct line from that switch to the multi pin connector under the seat, and both the rear lights go out together.
These rear connectors are all under the seat, on the left side, just above the shock absorber.
In the event that the red wire is not the problem, the other lines are routed as follows:
The B/Y wire goes to a 6 pin connector in the Reserve Lighting unit.
The L (bLue) wire goes to a 6 pin connector on the right handle bar, front brake light switch.
The one I would check first is the Red wire at the ignition switch.
post #5 of 5 (permalink) Old 11-10-2009, 12:05 AM
Love My Baby
rubyrick's Avatar
Why don't you start with checking the bulbs and their connections? That would seem to be the simplist place to start. Work your way back from there if the bulbs are good and connected well and no corrosion on the bulb ends. I've found most of the time when bulb connections are bad, it's because of tarnish or corrosion on the end the bulb or the socket they sit in. Take a pencil eraser to the tarnish, or scrape it off lightly with a screwdriver until it shines better. Then reconnect and try it again.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
