Battery plus ?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 10-21-2009, 03:06 PM Thread Starter
trekbiker's Avatar
Battery plus ??
Has anyone used the battery plus Battery that fits our bike?
I bought their sealed one day before yesterday as my old battery died - and now two days later I am pushing the bike to get it started again..
That can't be my bike - it aint movin'
trekbiker is offline
post #2 of 16 (permalink) Old 10-21-2009, 05:20 PM
I had a Battery Plus sealed/MF battery. Lasted a little over 3 years.
How long and at what amps did you charge it?
I know sometime they say they don't need charged, but I prefer to be sure the battery has a full & complete charge before installing it.
At most, 2amps until fully charged is the highest I usually go.
Lower amps for a longer time gives a much better charge than more amps for less time.
post #3 of 16 (permalink) Old 10-21-2009, 06:02 PM
Simple Solutions
seebeeare's Avatar
hows your charging system a bad charging sytem could have ruined your last batt and it could have been an issue but u soudl check to make sure the bike is chargong
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 16 (permalink) Old 10-21-2009, 06:36 PM
I have heard alot of bad reports on Batteries Plus motorcyle batteries, so I would avoid them. (My Westco lasted 5 years, and may still be going BTW)
You do need to check your charging system however as mentioned.
post #5 of 16 (permalink) Old 10-21-2009, 11:22 PM
HAWK
Ccspinner's Avatar
I have one in my bike with no problems, I know Bulldog has one to.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 16 (permalink) Old 10-21-2009, 11:55 PM Thread Starter
trekbiker's Avatar
Thanks for all the suggestions - I did charge the battery for a couple of hours - until the green light came on on the charger when I first got it - perhaps I'll charge it again this evening - How do you go about checking the charging system?
post #7 of 16 (permalink) Old 10-22-2009, 05:14 AM
Simple Solutions
seebeeare's Avatar
a simple check is to put a volt meter on the batt, take voltage readings across the batt at; off, idle, and 4k should be between 13-15 volts at 4k rpms
check all ground, stator and rr connections... in my signature there is a stator test and ther is an rr test in versus, clymers, and in the service manual,
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 16 (permalink) Old 10-22-2009, 03:30 PM
93VN750's Avatar
I have had bad experience with 2 of theirs, no more for me.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #9 of 16 (permalink) Old 10-22-2009, 06:32 PM Thread Starter
trekbiker's Avatar
Thanks for the help - it looks like I have a bad connector at my R&R - going out to PEP boys to try and match one up - The old battery leaked all over the connector and it is crumbling - - not keeping good contact - I'll let you know what happens - everything else seemed to check out pretty much OK - and when the battery is charged it fires right up - I sure hope it really is this simple
post #10 of 16 (permalink) Old 10-23-2009, 02:50 PM Thread Starter
trekbiker's Avatar
connector?
well - apparently you can't go buy a connector (that I have found) - also it looks like my stator is a bit shorted to ground - no wonder things don't stay charged. The battery charged up great off the bike the r&r seemed to check fine so it looks like I will be in for a bit of quality bonding time with my bike as soon as I get all the parts. Do I actually have to buy a new wiring harness just because one connector went kaput?
