Battery strap and box - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 10-16-2009, 09:18 PM Thread Starter
dbrain2002's Avatar
Location: NE, NV Wendover is to Salt Lake City, what Vegas is to LA
Has anyone had the hooked parts of the battery box break off, so that the securing strap/band won't connect any more?
I bought a new Westco m/f and it has now failed. When I went to replace it, I found the loose strap/band sitting on top of it. I had just gone over some rough terrain, so I assume that the battery took a bad bounce and caused the plates to short out. Who knows when the strap failed. Any way I am now out $80+ for a battery.
I have temporarily replaced the battery with a standard lead acid type and secured it with two 4 1/2 inch hose clamps. I can't see the point of buying a $75 battery box replacement just to risk these delicate little points from breaking again. I will howeverremove the lead acid battery for storage and replace with an AGM, M/F in the spring.
With all of the reported battery and stator problems reported on the site, I was wondering if this was additional cause of failure, strap fails, battery fails, stator fails.
dbrain2002 is offline
post #2 of 3 (permalink) Old 10-16-2009, 09:49 PM
The Professor
lance328's Avatar
I have not seen any with a broken strap, but it can happen. There was a problem with the Westco battery shorting out internaly, yours may be one of them. Below is a link for a used battery box at a great price. A shorted or weak battery can cause stator an R/R problems. Below is a link for an MF AGM battery that is designed for vibration resistance, and the new ones are 210CCA.
Battery
http://cgi.ebay.com/ebaymotors/Deka-...ehicleQ5fParts
Battery Box
http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 3 (permalink) Old 10-18-2009, 02:07 AM Thread Starter
dbrain2002's Avatar
Thanks
Thanks for such a complete and helpful reply. I was aware of the new battery, but not that it was supposed to be more vibration resistant. I am going to pass on the battery box for now, but it was great to see the part available and cheap. Thanks again.
