Kickstand interlock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 10-12-2009, 07:54 AM Thread Starter
Rook's Avatar
Kickstand interlock
Is there anyway to bypass the kickstand interlock switch without damaging the bikes electrical system?
I've tried cleaning mine but it still takes several tries of wiggling and kicking to get going. I don't see much point in replacing it just to end up in the same position down the road.
Unlesss there is a better design available....
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #2 of 14 (permalink) Old 10-12-2009, 09:17 AM
GIMPYRDR's Avatar
Don't know about a bypass for the switch. I found on mine (by accident, bike would not let me go anywhere) that the plunger was bent and stuck in the switch. I pulled it out and twisted it (the plunger) so it would not contact the kickstand and have been doing fine without problem. This isn't a suggested method. Damage could occur while trying this on an undamaged switch.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #3 of 14 (permalink) Old 10-12-2009, 09:18 AM
I would replace it. I have had my bike for about 5 years and my switch still works fine.
I had trouble with my yammy when i first got it, but working fine now.
post #4 of 14 (permalink) Old 10-12-2009, 12:02 PM
Adventuregeek
Tiki Mon's Avatar
I got one off Ebay (used) to replace my failed switch.
You can get going without it until you get a replacement, but you MUST BE CAREFUL. This allows you to ride away with the stand down. That would be very bad, and I'm not worth suing.
You can bypass it (temporarily!) by unplugging the kickstand switch connector. Then simply run a jumper wire across the contacts in the cycle side of the connector. The KS switch is "ON" when the stand is up, so this completes the circuit and fools the bike into thinking the stand is up. I rode that way for a week before my replacement switch arrived.
If you do a temporary bypass, I suggest making a bright red tag that says "REMOVE BEFORE FLIGHT" and hang it on your throttle grip. Don't remove it until you've raised the stand and it's safe to ride away. Yes, I forgot once...
Laissez les bon temps rouler!
Coastered, R&R relocation, MCCT's, Koso mirrors, Memphis Shades windshield, Mutazu GA hard bags, big monkey in the saddle. ATGATT: Olympia AST hi-viz jacket, Recon 2 (convertible) pants
Tiki Mon is offline
post #5 of 14 (permalink) Old 10-12-2009, 04:39 PM
You know, back in the day when I first started riding, they did not have switches on the kickstand. It was just a given that you made sure the thing was up before you took off on the bike.
You also had to remember to turn the fuel "on"....
Nowadays it seems we need fail-safes for these , as either we are just more stupid, of just more lazy.
I realize that the only reason there are switches on the kickstand is because some idiot forgot to kick his up before he rode off, and ended up dumping the bike.......then of course he sued the maker of the bike. (I do believe it was Kawasaki)
My dad always said they make things "idiot proof" because there are just too many idiots.
Then I would say I thnk there is at least one lawyer for every one idiot.
I was looking at those 4 wheel ATV's at my local dealer this week and counted 12 warning labels stuck to various parts of the thing. .....LOL
post #6 of 14 (permalink) Old 10-12-2009, 04:52 PM
STUMPYSKAW's Avatar
Caution waking up alive may cause death or serious injury!
My switch don't work, just have a bad habbit of putting the kickstand up before I click it into gear.lol
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #7 of 14 (permalink) Old 10-14-2009, 01:56 AM
About 15-20 years ago Paul Harvey was telling a story about the warning labels that companies have to put on everything they sell. A step ladder came with a thousand word warning label. And I believe I saw a Ruger revolver with 4 or 5 lines of warning forged or engraved into one side of the barrel. All this BS just because common sense is not so common as it used to be.
post #8 of 14 (permalink) Old 10-14-2009, 09:40 AM
fergy's Avatar
I remember a few years back a comedian had a stand up routine that was centered around warning labels on products. All about who could have been stupid enough to have the company feel like they needed to warn against using their product in that way. Kind of also reminds me of "Here's Your Sign"...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 14 (permalink) Old 10-23-2009, 11:04 AM
ravdaveed's Avatar
Send a message via AIM to ravdaveed Send a message via Skype™ to ravdaveed
My switch doesn't work at all either, actually, I didn't really even think about there being one on the bike till someone on here mentioned it... Then I looked at it, and sure enough, the switch exists, does not work, but it is there. I knew that other bikes I've been on (my in-law's bikes) have them, and they work, but mine didn't...
But, it's all the same to me, I figure that as long as the switch not working isn't screwing anything up then I don't really care if it doesn't. I haven't even attempted to ride off with the kickstand down, my helmet on the sissy bar and not on my head, sure, I've done that once or twice, but not the stand down.
All I can say is that McD's has a warning label about there hot coffee being hot for reason...
1990 VN750
Got it on 9/10/09
7683 original miles when I got it
7870 current (constantly adding more)
Mods already on bike:
Kuryakyn Iso Grips with throttle boss
Kuryakyn Iso pegs with heel rests
Windshield (not sure what brand or style, just look at my pic)
Leather Saddle bags
Leather t-bag
Mods since I got it:
Wet Battery
Many more to come...
ravdaveed is offline
post #10 of 14 (permalink) Old 10-24-2009, 11:57 AM
Undercover Sportbiker
AJCruzin's Avatar
Didn't someone on this forum wreck out cause their side stand was down?
AJCruzin is offline
