Truck cab clearance lights as tail lights? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-09-2009, 04:38 PM Thread Starter
Anyone tried using truck cab clearance lights are "blister" turn signals? Im thinking about trying it , but not sure if will be seen as well as not changing them. I want a more streamline look.
6204 is offline
post #2 of 9 (permalink) Old 10-09-2009, 05:43 PM
They will have to be red for tail lights.
post #3 of 9 (permalink) Old 10-09-2009, 07:52 PM
dirtrack650's Avatar
They won't be as bright as blinker bulbs (27 watt) but they will work.
I've purchased several LED clearance and stop/tail/turn from truck stops for my bikes.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 9 (permalink) Old 10-09-2009, 09:05 PM Thread Starter
i was going to shoot for LED clearance lights front and back. my problems are
1. im wondering if they are bright enough to be seen in front and on the sides.
2. how i will make them be running lights AND turn signals.
6204 is offline
post #5 of 9 (permalink) Old 10-10-2009, 11:39 AM
MOST (not all) LED's are not as visible from the sides. LED lamps are directional: they're bright where you point them.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #6 of 9 (permalink) Old 10-10-2009, 10:03 PM
Hoser
junkyardroad's Avatar
I used them as turn signals on mine. They work fine. Way brighter than the stock turn signals.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #7 of 9 (permalink) Old 10-11-2009, 09:59 PM Thread Starter
have any pictures?
6204 is offline
post #8 of 9 (permalink) Old 10-15-2009, 07:19 AM
A pic will surely help as most have taken pics from head on. You should still have some side visability as the lens refrects the light going through it. Hence lighting it up. What would really help is a short video, that way you could see it as signal & marker at the same timeIt would be interesting to see a stock to led comparison from the side.
post #9 of 9 (permalink) Old 10-15-2009, 06:45 PM
I bought some surplus LED lights with 1157 bases. They have 12 LEDs alternating between pointing straight back, and around the circumference. Just to check it out, I replaced one incandescent bulb with the LED, and had my wife apply the brake while I checked from 30 feet to the back and sides. It is noticeably brighter and redder from both the back and side. The incandescent bulb now looks orange in comparison.
