Bike died - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 10-08-2009, 04:41 PM Thread Starter
Richmond, VA
Bike died
Riding along and suddenly lost all electricity. No power any where. I'm guessing R/R. How do I check? Any other suggestions on where to look?
Rodd
'95
mine 05/09 19.5k; 11/09 30k
DONE
RAM Mount
Kuryakyn 12 volt socket
mirrors
paint Speedo and Tach
LED turn sigs
LED Brake
KAW luggage rack
Spiders Den Laptop Bag
KAW Saddlebag kit
Bridgestone Exedras
Protac Backrest
JJCyclepass
Kuryakyn Levers, Grips & Throttle Boss
Spencer seat w/B&H cover
new ignition switch
handlebar clock
cup holder
Mutazu bags
LED Bulbs
New Fuel Tank & Fenders
windscreen
TO DO
Hiway pegs
Rodd is offline
post #2 of 14 (permalink) Old 10-08-2009, 04:47 PM
Main fuse, maybe under seat. Ignition switch or a dicconnected cable from batt.
post #3 of 14 (permalink) Old 10-08-2009, 04:49 PM Thread Starter
Richmond, VA
How do you check ignition switch?
Rodd
'95
DONE
RAM Mount
mirrors
LED turn sigs
LED Brake
KAW luggage rack
KAW Saddlebag kit
Bridgestone Exedras
Protac Backrest
JJCyclepass
new ignition switch
handlebar clock
cup holder
Mutazu bags
LED Bulbs
windscreen
TO DO
Hiway pegs
Rodd is offline
post #4 of 14 (permalink) Old 10-08-2009, 05:35 PM
'85 Bobber
drodeo17's Avatar
Also Check the electrical connection that plugs into the hand clutch. Mine came loose on me yesterday and I just plugged it back in.
Completed
Stripped down to motor and frame
Front- 100/90-19 Avon Wide White Walls (cause I couldn't find the 110's)
Rear- 170/80-15 Avon Wide White Walls
Custom Lowering bracket (no shocks)
Powder coated rims Red
14" Apes (cause they didn't have 16" in)
Custom Seat
Ear Shaved
Aftermarket headlight & tail light
Flat Black Paint
Custom Exhaust with Wrap
New Turn Signals
kuryakyn 6180 Grips with helmet locks
Highway Brackets from ccspinner
Kuryakyn Longhorn Offset Dually Highway Pegs
drodeo17 is offline
post #5 of 14 (permalink) Old 10-08-2009, 06:38 PM Thread Starter
Richmond, VA
Battery connection is fine. Fuses are fine. Cables to clutch and throttle fine. Still no power to anything. No emergency lights. These should not be affected by ignition (?)? I need more suggestions.
Rodd
'95
DONE
RAM Mount
mirrors
LED turn sigs
LED Brake
KAW luggage rack
KAW Saddlebag kit
Bridgestone Exedras
Protac Backrest
JJCyclepass
new ignition switch
handlebar clock
cup holder
Mutazu bags
LED Bulbs
windscreen
TO DO
Hiway pegs
Rodd is offline
post #6 of 14 (permalink) Old 10-09-2009, 01:00 AM
The Professor
lance328's Avatar
Check and clean the frame ground.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 14 (permalink) Old 10-09-2009, 12:11 PM
aka Smokymtnvulcan
Ablerider's Avatar
Was the battery dead when the bike stopped running on ya? I was riding mine and stopped at a stop sign and the motor died..........went to recrank and nothing! That's how I found out my charging system was on the fritz. Spent an interesting day in North Georgia waiting on my trailer!
VROC #28359 Murphy NC
Patriot Guard Rider
US Army (Retired)
NC Law Enf (Retired)
VN750A3 New RR, New Stator, New Tires, Cleaned Carbs, New Choke Cable, Degoated and Marbled, replaced ACCT with MCCT, Custom LED Signals F&R, Custom Luggage Rack.
Did Tail of the Dragon in 1972 and again 07/2011
I like pipes I can hear!
I wear leather so I won't hurt too bad!
I wear a half helmet so I can see and hear better!
Not a poser, not an outlaw biker, JUST ME!
Ablerider is offline
post #8 of 14 (permalink) Old 10-09-2009, 04:02 PM
fergy's Avatar
This sounds like dirty or corroded connections somewhere. Battery terminals, grounds etc. Have you pulled your battery connections and check them for corrosion? It screams corrosion somewhere, or a loose connection, maybe ignition switch malfunction...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 14 (permalink) Old 10-09-2009, 04:36 PM Thread Starter
Richmond, VA
I've got directional and emergency flashers running now. I swore they did not work before I jiggled the key for the umpteenth time. No idiot lights though & no cranking. Battery is fine. I'm leaning towards ignition switch failure. Has can I test it? Don't want to spend money I don't have to.
Rodd
'95
DONE
RAM Mount
mirrors
LED turn sigs
LED Brake
KAW luggage rack
KAW Saddlebag kit
Bridgestone Exedras
Protac Backrest
JJCyclepass
new ignition switch
handlebar clock
cup holder
Mutazu bags
LED Bulbs
windscreen
TO DO
Hiway pegs
Rodd is offline
post #10 of 14 (permalink) Old 10-09-2009, 04:39 PM
Most of the guys and gals here take it apart and clean it and lube it. Be sure to disconnect the battery before cleaning it.
