Strange Voltage Readings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-06-2009, 09:25 PM Thread Starter
Love My Baby
rubyrick's Avatar
Hi all. Please let me know if this is normal or if it's an early sign of stator malfunction:
Battery voltage when off is 12.79, at idle is 13.35, at just past idle (1200 rpm or so) it's 14.68, all which is good. But as I increase rpm's, the voltage goes down a bit: at 2000 it's 14.55, at 3000 it's 14.45 and at 5000 it's 14.18
All the numbers show the battery is charging, but is it a bad sign that the voltage goes down as the rpm's go up?
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #2 of 4 (permalink) Old 10-07-2009, 02:49 AM
The Professor
lance328's Avatar
No problem !!!!!
Most people fail to realize that the higher rpm's require more power to the ignition system, and higher rpm's mean higher stator output and once you hit 14.50v the R/R needs to bleed off any extra voltage to keep from doing system damage.
Your system is working flawlesly!
Someone has you in their good graces!! ???
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 10-07-2009, 02:59 PM
Drive less, ride more...
theauhawk's Avatar
Great thread and info--thanks guys.......!
'05 VN750
theauhawk is offline
post #4 of 4 (permalink) Old 10-07-2009, 09:38 PM Thread Starter
Love My Baby
rubyrick's Avatar
Thanks Lance. I guess I thought the R/R should hold the voltage steady at the proper max voltage so I was worried that something might not be working properly. But I guess the higher the stator's output the more voltage the R/R needs to bleed and it's not a perfectly linear relationship. I feel much better now after your reassurance. Thanks again...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
