New Stator - Votage lower at higher RPM! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 35 (permalink) Old 10-02-2009, 12:23 AM Thread Starter
Skierbob
Exclamation New Stator - Votage lower at higher RPM!
I just replaced my old shorted out stator and got wierd results when checking the bike with the new one. At just above idle (about 1500RPM), I get 14.2 volts but as I rev the bike higher the voltage drops til it is only about 13.6 v at 5,000 RPM! With the top two fuses out (i.e. no lights), I get .2 to .3v more but the same strange drop as RPM climbs. The R/R passed the Clymers resistor check before replacing the shorted stator. Any suggestions about where to look next for the problem? I'm worried that whatever is drawing enough current to cause the voltage to drop at higher RPM is what blew the stator in the first place.
Thanks in advance for any suggestions.
Skierbob is offline
post #2 of 35 (permalink) Old 10-02-2009, 12:53 AM
Welcome back Skierbob, I see the only other post you ever made here was 2 years ago last June. Where ya been? I can't help with any explanation for the wierd voltage readings dropping as the rpms climb higher. lance328 will be around sooner or later, and have some advice for where to start looking. Now ya'll come back, ya hear.
post #3 of 35 (permalink) Old 10-02-2009, 01:04 AM
Now what
Ironman's Avatar
That's weird for sure. But as long as you get over 13.5 volts at over 2500 rpm, and less that 15 or so at 5000, the system's doing what it's suppose to.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #4 of 35 (permalink) Old 10-02-2009, 02:08 AM Thread Starter
Skierbob
Thanks for the responses. I guess I'lll just nose around a little more and put some 20 Amp fuses in the stator outputs and ride it with my fingers crossed if I can't find anything else wrong. I sure don't want to replace the stator again. What a pain! Thank goodness for all those on this forum that have gone before me on this.
As for where I've been,... riding of course! About 6,000 miles a year, all pleasure. Ride on everyone!
Skierbob is offline
post #5 of 35 (permalink) Old 10-02-2009, 02:18 AM
Simple Solutions
seebeeare's Avatar
you would be better off with a olt meter to monitor it... if u fuse the stator and one of the 3 legs go your bike is gonna try and send excess power though the other two leads causing the stator to operated at a higher temperature and the wire's wont be capable of allowing that much current through... fuses will do more harm then good...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #6 of 35 (permalink) Old 10-02-2009, 10:29 AM
fergy's Avatar
This sounds to me like your r/r is acting up. I know you said it tested good, but it is, after all, a voltage regulator and it sounds like it isn't regulating correctly!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 35 (permalink) Old 10-02-2009, 11:50 AM
I replaced my r/r. Now I get 12.5 volts most of the time at any rpm. When I add a load to the system it goes up to 13.4 or so. The volts do drop down at idle rpms.
I replaced the r/r because erratic readings. At times it would go over 15 or 16 volts.
post #8 of 35 (permalink) Old 10-02-2009, 12:52 PM
I had a conversation with Tim at TPE about fusing the stator. He had never heard of it and felt that doing so could acutally hurt the stator. The stator puts out full voltage all the time, it is strictly mechanical, has no regulating capability, and the 3 legs work together. If you take out one leg, the other two are are less capable of putting out the required voltage but the demand is still there. Since they are less capable of putting out the required voltage or amps, the other two fuses will never blow. A volt meter is a much better way of monitoring the charging system. Kuryakyn makes a nice little unit for a reasonable price, I put one on my bike, mounted it right between the gauges and it looks nice. It's got a dimmer for night riding.
http://www.amazon.com/KURYAKYN-GAUGE...498556&sr=8-19
AceMcgyver is offline
post #9 of 35 (permalink) Old 10-02-2009, 01:38 PM
I do have a theory..
Look at the pictures below:
- Blue line is stator output voltage at low rpm.
- Red line is stator output voltage at a higher rpm.
- Black line is the battery nominal voltage.
- Green line is the charging voltage R/R is trying to achieve.
The first picture shows one positive half wave of the stator output voltage.
The second picture is a detail of the first one, where the voltage rises beween the battery voltage and the charge voltage.
While the voltage is below the battery voltage, there is no output from the R/R and a voltmeter will show the battery voltage. As soon as the voltage rises above the battery nominal voltage, the battery starts to receive charge current. But when the voltage goes above the R/R set voltage, it cuts off the R/R output. I have colored the triangles where charging occurs. As you can see, at low rpm the triangle area is larger than at higher rpm. Since a voltmeter shows the root-mean-square (effective) value of the voltage, it will actually show a higher reading at lower rpm. I used the same timescale for both cases (lazy me), but actually the dirrefence is even more when the blue curve is stretched. On the other hand, at higher rpm those red charge pulses occur more often, which compensates.
In practise the stator output voltage is not as clean as in the pictures. As soon as it gets above the battery voltage, it is the stator which supplies all the power + the charging current. This tends to restrict the rise of the output voltage. But with a battery which has seen it's best days, less than perfect connections to the battery and a light load, you could see a lower voltage at higher rpm.
Did it make any sense to you? Could explain what niterider is seeing.
pappa is offline
post #10 of 35 (permalink) Old 10-02-2009, 10:38 PM Thread Starter
Skierbob
Thanks Pappa for a great explanation of my readings and AceMcGyver and Seebeeare for the comments on putting fuses in the stator outputs. Pappa, your graphs make perfect sense and make me much more comfortable that all is probably well with the bike.
I am very concerned now with the fuses I put in my stator outputs. I thought I read that a few other people on this forum did this so I thought it was a tried and proven insurance policy. Anyone else want to weigh in on this before I pull the fuse holders back out of the circuit?
By the way, the bike is running great! Nothing like a hot spark to notch up an already hot ride! In fact I'm not sure the bike ever ran this good. Makes me think the stator may have been bad since I bought the bike for my wife with 2700 miles on it three years ago. I thought I got it for a great price but I guess not if it was already needing a $800 - $900 repair. Oh well, chalk it up to experience. All's well that ends well!
Skierbob is offline
