Stator Replacement Parts List - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 09-24-2009, 03:09 PM Thread Starter
ExNewbie..Still Learnin'!
rsawyer's Avatar
Question Stator Replacement Parts List
Looks like I'm going to finally replace my stator (the "carrying a spare battery so I can get home" trick is getting old! ) Anyway, I've looked through numerous stator posts but can't seem to find a definitive list of gaskets, seals, grommets, etc., that I will need to do the job right. Planning on replacing all as long as I have it torn apart. Does anyone have one or know a thread that has a list like that? Any help appreciated! (gonna need all I can get!! )
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #2 of 9 (permalink) Old 09-24-2009, 03:13 PM
fergy's Avatar
Seems like Lance posted that in the last week or so, but I could be wrong.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 9 (permalink) Old 09-24-2009, 03:35 PM
letitflight's Avatar
cheapcycleparts.com here are the gaskets u need
11060-1089 GASKET,GENERATOR COVE $11.17
11060-1086 GASKET,GEAR CASE $7.48
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #4 of 9 (permalink) Old 09-24-2009, 03:47 PM
Simple Solutions
seebeeare's Avatar
if u can id recomend getting your rewounde at http://www.tpe-usa.com/ cant beat the price i just sent mine out today
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #5 of 9 (permalink) Old 09-24-2009, 05:47 PM
flitecontrol's Avatar
From what I hear, they are, or should be, better than the original.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 9 (permalink) Old 09-24-2009, 09:51 PM
Concert connoisseur
wib714's Avatar
I have a list in my sig, under stator replacement.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 9 (permalink) Old 09-29-2009, 12:33 PM Thread Starter
rsawyer's Avatar
Thanks WIB, forgot that you had done that.
Appreciate the help!
'89 Vulcan 750
VROC# 30232
Kaw Engine Guard
Diehard M/F Battery
Stator Replaced
Voltmeter Installed
Splines Lubed
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
NGK Iridium Plugs
rsawyer is offline
post #8 of 9 (permalink) Old 09-29-2009, 12:44 PM Thread Starter
rsawyer's Avatar
Planning to do so, sounds like a great place to do business with quality workmanship. Will also probably send my starter motor as I think I have a flat spot or two in it.
'89 Vulcan 750
VROC# 30232
Kaw Engine Guard
Diehard M/F Battery
Stator Replaced
Voltmeter Installed
Splines Lubed
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
NGK Iridium Plugs
rsawyer is offline
post #9 of 9 (permalink) Old 09-30-2009, 08:51 PM
I just got my stator back from TPE and the bike running with it. I still have charging issues but the stator is not part of that. It's putting out 20 VAC at 600 RPM and 60 VAC at 3000 RPM. Nice workmanship, not sure about the support yet, got a regulator from him at the same time but haven't been able to contact him in 2 weeks. I'm hoping he's just on vacation or something.
For gaskets since this was the 3rd time I was in that side of the bike I just used RTV silicone and it seems to be working fine. I was worried about binding on the shifter but there seems to still be plenty of clearance.
AceMcgyver is offline
