battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 09-21-2009, 01:04 AM Thread Starter
1985 kawasaki vn700 a1
Send a message via Yahoo to newguywithbike
battery
hay guys got a new problem wanted to see if u have any ideas. i bought a new battery from walmart and after three days the battery is dead. i may have not charged it long enough but i was wanting to know if there is something else wrong with it. let me know what to do
newguywithbike is offline
post #2 of 3 (permalink) Old 09-21-2009, 01:21 AM
Simple Solutions
seebeeare's Avatar
id have the battery tested is it a mf agm batt? if the batt is bad see if u can trade up... now im leaning towards the electrical system i start with a fully charged batt (its not a good idea to use our bike to charge batt) and test voltage at idle and at 4000k and repost to the thread... if the bike is charging u should get close to 14volts at 4000 roms if its not there is a test in my signiture for testing the stator and the clymers makes a good refrence to testing the rectifier...
i do recomend the agm battery no matter what ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 3 (permalink) Old 09-21-2009, 07:59 AM
Love My Baby
rubyrick's Avatar
You know, it's possible your problems from your other thread are related to your battery issue. Get the battery checked at autozone and see if it's got a dead cell in it or something. If the battery is good, fully charge it and reinstall (unless it's a wet cell, then buy a maintenance free AGM battery), then check it out as seebeeare stated to see if your charging system needs work.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
