headlight won't work? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 09-20-2009, 01:16 AM Thread Starter
My buddy noticed today that my headlight was not on right before we were pulling out of his driveway. So we took the bulb out and went and bought a replacement(From walmart. Only store open at the time) It was a GE 9003 halogen bulb that matched up to the existing bulb that was in the head lamp. The bulb that was pulled from the bike however was a Japanese bulb with the number 3401 on the bottom of it. The original bulb(3401) is bad as one of the tiny springs broke off and is moving around in the glass. When we put the new one in though the bulb did not turn on. We checked the fuses and everything was good. Is this the wrong bulb? If so will i be able to buy the bulb I need at a local auto shop or what? Thanks in advance Ian.
Ian33 is offline
post #2 of 17 (permalink) Old 09-20-2009, 01:25 AM
I got mine at a local auto parts store. Have done it twice, at different stores. It's a standard bulb. But I use halogen bulbs too. All auto stores carry them.
Not sure about the number on the one you bought.
Could be a bad bulb from the start.
Did you pull it out and re-plug it back in again?
And check your dimmer switch to see that it's in the right position.
Also, start the bike. The light should burn without it started, but when in doubt, check everything.
Might also check the connectors on the wiring--if you pulled something loose when you opened the light bucket up the first time.
vn750angky is offline
post #3 of 17 (permalink) Old 09-20-2009, 01:33 AM Thread Starter
Yes we plug it in and out several times and even had another buddy come over and look at it. Never worked and couldn't figure it out. By dimmer switch do you mean high/low beam if so yes switched back and forth every time we re plugged and nothing. Also we did start it nothing. Check everything we could see for good connections but just to make sure it was connected we did not check voltage.
Ian33 is offline
post #4 of 17 (permalink) Old 09-20-2009, 01:47 AM
Before you spend for a new light bulb, you might try putting the old one back in and see if high beam works. If it's not burned out (2nd broken spring inside), you should see it light up. If it does, then go get another bulb that matches the original.
Just a quick and simple test before you buy another bulb....
post #5 of 17 (permalink) Old 09-20-2009, 01:52 AM Thread Starter
did that to. Any idea what else it could be?
Ian33 is offline
post #6 of 17 (permalink) Old 09-20-2009, 01:58 AM
Nothing else to offer at the moment.
Maybe somebody else will offer something.
If I think of anything--other than go ahead and buy a good replacement lamp and try it...
post #7 of 17 (permalink) Old 09-20-2009, 02:02 AM
The Professor
lance328's Avatar
Your HL relay probably took a crap, it happens alot. At the Junction/fuse box locate the blue wire in the TOP connector and move it to the open slot beside it in the connector. Your HL should now come on when you turn on the key. If it does you can replace the JB or leave as is.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 17 (permalink) Old 09-20-2009, 02:06 AM
Now this makes good sense. Forgot about the relay.
I put a new relay in mine when I wired my ignition switch. Bypassed the junction box altogether--which defeats the safe-on high beam system. But I can live with that. My volt meter wires into my headlight circuit so I can see when my headlight drops out of the system.
post #9 of 17 (permalink) Old 09-20-2009, 02:45 AM Thread Starter
what is a jb?
Ian33 is offline
post #10 of 17 (permalink) Old 09-20-2009, 04:23 AM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
READ post #8..................
Originally Posted by Ian33 View Post
what is a jb?
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
