Battery Tender - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-04-2009, 02:43 PM Thread Starter
VulcRider24's Avatar
Battery Tender
Just wondering if I should go with the regular battery tender or save some money and get the battery tender junior. Is the junior safe to use on my MF battery all winter?
1994 Kawasaki Vulcan 750 named Jinba Ittai (Japanese for "Horse and rider in perfect harmony").
Jardine Pipes
Splines Lubricated
Painted Instrument Bezels
Headlight Visor
Chrome engine guard
Leather Fork Bag (contents: Pressure gauge, tools, and a Book of Psalms)
Yuaso MF AGM Motocross battery
Kenda Kruz Front tire
Duro Boulevard rear tire
"Buy the ticket, take the ride."
-Hunter S. Thompson
VulcRider24 is offline
post #2 of 6 (permalink) Old 09-04-2009, 03:08 PM
cglennon's Avatar
The key is to get one with smart technology that will turn off if the battery is fully charged. A good AGM battery will loose much less charge when not in use (compared to a conventional wet battery). So, the junior should be fine IF it has technology to turn itself off and on when needed, like this one.
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 6 (permalink) Old 09-04-2009, 03:17 PM
At Least I Can Spell!
msh1156's Avatar
I bought this one from the local Cycle Gear shop the same day I bought my new AGM battery. Excellent combo.
http://www.cyclegear.com/spgm.cfm?L1...em=VAN_74-9120
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #4 of 6 (permalink) Old 09-04-2009, 04:00 PM
Love My Baby
rubyrick's Avatar
Save the money and get the Battery Tender Junior. It trickle charges at a slower rate so it is even less likely to damage your battery. Either one works fine.
HINT: Don't connect and disconnect your battery to the tender daily because the initial phase of charge is higher, until the unit senses the battery's charge level. This initial phase can potentially cause some problems IF you disconnect and reconnect frequently. Leaving the unit on all winter won't be a problem though, so don't worry.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 6 (permalink) Old 09-04-2009, 06:34 PM
They included a Battery Tender Jr. when I bought my bike and it has worked just fine for me.
post #6 of 6 (permalink) Old 09-04-2009, 09:18 PM Thread Starter
Ok thanks guys. Junior it is haha. I had to leave my bike at home and winterize it when I went back to school. It's been like two weeks and I already miss her so much. It's gonna be a long winter for sure.
Jardine Pipes
Splines Lubricated
Headlight Visor
Chrome engine guard
-Hunter S. Thompson
