Ground problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-28-2009, 08:15 PM Thread Starter
Ground problems
Ok i searched the threads but did not find an answer to this question.
Last Saturday, i was on a poker run. at the first stop, i went to crank the bike back up and nothing. I thought is was dead. Tried it a few more times and noticed smoke coming from under the seat. that is never a good thing. I took off the seat and noticed the wires connected to the fuel sensor were completely melted. (the fuel guage has never worked anyway) So, i unplugged the fuel gauge wires under the seat, and the bike was dead. I figured I killed the battery. It push started just fine and i finished the run by getting pushed off at every stop. When I hot home, i took the battery off anf put in on the charger. Reinstalled and nothing. Checked the solenoid and got good readings and clicking from it. Figured it must be the starter.
I pulled off the starter and tested it. It seemed fine so i figure the battery must be bad. Since it was a wet cell i decided to replace it with a MF battery. My big crank battery came today. I installed it right away and nothing. I figure, it must be a connection somewhere. I ran a jumper to the positive studs on the starter and connected it to the battery,nothing! then I ran a jumper from the negative side to the starter connection with the frame. The starer turned and the engine tried to fire.
So, my conclusion is a bad ground somewhere. Anyone have any advise on where to start before I trace every wire down. I noticed that the negative sideisnot simply grounded to the frame like a car would be. It is connected to a yellow striped wire and disappears into the harness and under the tank.
Any help would be awesome! trying to go on a charity ride this weekend.
cwalker is offline
post #2 of 9 (permalink) Old 08-28-2009, 08:28 PM
The Professor
lance328's Avatar
Check the battery to frame and the frame to engine ground connection. Remove, clean then reinstall.
Your ground wire from the battery should be the same as a car, connected to the frame.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 9 (permalink) Old 08-28-2009, 08:30 PM
I could be wrong, but there should be a ground to the frame from the battery under the right side cover.
When you unplugged the wires to the fuel sensor did you fix the damaged wires?
Guessing you did check the fuses. Do you think the smoke was from the wires of the junction box...? You might have fried something in there.....
post #4 of 9 (permalink) Old 08-28-2009, 08:33 PM
The Professor
lance328's Avatar
The ground to frame is under the seat at the battery, the frame to engine ground is under the right cover.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 9 (permalink) Old 08-28-2009, 08:41 PM
Simple Solutions
seebeeare's Avatar
mine did the same thing and it was the batt to frame..... could be either though my connection at the frame wiggled and broke completly apart...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #6 of 9 (permalink) Old 08-28-2009, 09:17 PM
dirtrack650's Avatar
My vintage XS650 Yamaha did the same thing: The battery ground rotted enough to look like it was connected, but no voltage was flowing (voltage flows from ground to positive).
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #7 of 9 (permalink) Old 08-28-2009, 10:44 PM
Hoser
junkyardroad's Avatar
I removed my ground wires for cleaning last nite. Surprised to find they were bolted to a painted surface! I used Dremel to grind off the paint, a Scotchbrite pad for the wires and engine case. FWIW, I had a really nice factory crimped 00 wire from my last custom build and used it to replace the batt to frame shorty. And I ran a second frame to engine wire, 10 guage, with shrinkwrapped crimped-then-soldered terminals.
Does it sound like I have had ground problems B4?
Pull your tank and side covers and examine all of your harness. I bet you will find more than the sender wires melted.
Good luck, and keep a fire extinguisher handy.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #8 of 9 (permalink) Old 08-28-2009, 10:55 PM
Hoser
I also wonder if these kind of ground problems could lead to stator r/r failure. First thing that crossed my mind when I saw it.
post #9 of 9 (permalink) Old 08-31-2009, 11:51 AM
fendereff's Avatar
Send a message via AIM to fendereff Send a message via MSN to fendereff Send a message via Yahoo to fendereff Send a message via Skype™ to fendereff
I had the same problem a few months ago. It was the batt to frame wire and wiggled loose. Then the connector broke off at the terminal a few weeks later. Mine had been smoking as well and melted some of the wires. It does sound like a grounding issue.
fendereff is offline
