new battery compartment... nosomuch by choice - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-06-2009, 08:57 AM Thread Starter
so my orig battery had leaked all over the R/R, batt compartment and fuzebox leaving all three about useless. R/R and fuzebox were replaced and batt compartment was cut out and i had to fab up a new one. this is how i did it and its been working pretty well so far... in case anyone else has a similar idea or need.
i suggest poprivets as opposed to bending sheet metal unless you have a sheet metal break. I bent this stainless over a 4x4 piece of angleiron with a sledge, it was a pain in the ass. the angles were scavanged from my scrap metal pile but i think you get them at home depot in the lumber section. i pop riveted them on, backside to hold the batt in and frontside to mount the coil.
it does however fit in the bike fine
and holds a much larger battery
you will of course have to ensure you get good elec contacts through the box since the bolts that hold it on ground parts of the elec system. also, once its on you may have to figure out where to put everything back in, i had to lengthen some of the wires on the harness to reroute them and drill some more holes to bolt up the fuzebox and other various items.
i've ridden it around a fair amount since doing this and havent had the swingarm hit the bottom yet, even going over speed bumps. i believe it is slightly higher than the original R/R location was.
ID:	2203   Click image for larger version
ID:	2204   Click image for larger version
skaere is offline
post #2 of 10 (permalink) Old 08-06-2009, 09:55 AM
Nice fab work!
Hizzo also made a batterybox that held a much larger battery.
post #3 of 10 (permalink) Old 08-06-2009, 11:42 AM
flitecontrol's Avatar
Stainless is GOOD!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 10 (permalink) Old 08-07-2009, 06:14 AM
750Doug's Avatar
Nice job on that.
And on the pics too!
750Doug is offline
post #5 of 10 (permalink) Old 08-07-2009, 06:19 AM
Newb with a Bullet!
krebsne's Avatar
Genius! So they can hold a larger battery... are they? Is there an advantage to that? If so how would you know what battery to get? What specs do you have to match? Great work!
Current VN: 03 VN1600A
Past VNs: 92 VN750A, 98 VN1500A
Future VN: 94/97 VN1500A basketcase/bobber
krebsne is offline
post #6 of 10 (permalink) Old 08-07-2009, 08:53 AM
the advantage to a larger battery is more Cold Cranking Amps, and a larger storage capacity so if and when your stator goes, you have more time to get to a place to repair it. The down side is it takes longer for the stock charging system to bring a week battery back up,
post #7 of 10 (permalink) Old 08-07-2009, 10:12 AM
cglennon's Avatar
Wow, folks on this site can build just about any VN750 part, better than Kawa! Perhaps, the lot of you talented folks could get together and build a bike from stratch. I have no doubt that it would be amazing!
Chris Glennon - Portland, OR
cglennon is offline
post #8 of 10 (permalink) Old 08-07-2009, 11:28 AM
It would have a stator that was much easier to replace for sure!!!
"Black Beauty"
Old Blue
post #9 of 10 (permalink) Old 08-07-2009, 12:40 PM
Originally Posted by hyperbuzzin View Post
Nice fab work!
Nice work skaere. The stainless steel is a great idea too, I think.
Here`s a link to Hizzo`s gallery with pics of his battery box, stator rewind and tail light, brake light LED mods. https://www.vn750.com/photopost/showg...500&ppuser=607
post #10 of 10 (permalink) Old 08-07-2009, 05:36 PM
I am going to try and build a bike from scratch this winter...if i get home in time
