Bike runs; lights don't - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-02-2009, 01:25 AM Thread Starter
Chivo140's Avatar
So I was riding home from work tonight and all of a sudden my light went out. And I mean all of them. Headlight, blinkers, panel and gages. I checked the fuses and they all seem fine. The hazards will work and when I turn the key to “push” the break light comes on. What happened?
Chivo140 is offline
post #2 of 5 (permalink) Old 08-02-2009, 01:29 AM
The Professor
lance328's Avatar
Check your battery connections and frame grounds, sounds like another ignition switch needs cleaning.
If you push the key and turn all the way right the tail light only will come on.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 08-02-2009, 03:30 AM
yup sounds like the infamous ignition switch
post #4 of 5 (permalink) Old 08-02-2009, 08:27 PM Thread Starter
Chivo140's Avatar
OK, how about this
I pulled the ignition switch off opened it up and one of the leads was broken off if not lose and then knocked off by me. Can I simply solder it back on or is it more complicated than that
Chivo140 is offline
post #5 of 5 (permalink) Old 08-02-2009, 08:30 PM
The Professor
lance328's Avatar
You should be able to sloder it back on.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
