Air Horns vs Electrical Power - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-29-2009, 07:24 PM Thread Starter
Ratbiker
groove_puppy's Avatar
I've replaced my alternator once and don't want to do it again. If I put air horns on the bike am I risking frying anything on the stock electrical system?
'86 VN750 (mods in chronological order)
Ear shave and rejet with Uni pods
Cobra slashcuts
Gel cell battery
Cut rear frame and bobbed rear fender
New rear turn signals
Sidemount license plate and tail light
Fabricated solo seat
Inverted clubman bars
11" MDI shocks
Removed center stand
Modified mount for sidestand
Bike flat blacked
Exhaust header tape and BBQ paint
Custom mirrors
Removed front turn signals and horns
Fitted cafe fairing
groove_puppy is offline
post #2 of 16 (permalink) Old 07-29-2009, 07:57 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I put a Stebel Air Horn on mine and as long as you use the Relay that comes with it there is no difference in the power draw than the original horns. And the air horn will absolutely let someone know you are there. It was an easy install.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #3 of 16 (permalink) Old 07-29-2009, 08:06 PM
The Professor
lance328's Avatar
Adding a few accessories on our bikes is actualy better for the charging system then adding nothing. The excess power is being used instead of being bled off by the R/R, which adds more heat to the R/R and shortens it's life span.
Unlike an alternator a stator constantly produces electricity and what ever is not used is has to go somewhere.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 16 (permalink) Old 07-29-2009, 10:27 PM
Love My Baby
rubyrick's Avatar
Originally Posted by lance328 View Post
Adding a few accessories on our bikes is actualy better for the charging system then adding nothing. The excess power is being used instead of being bled off by the R/R, which adds more heat to the R/R and shortens it'slife span.
Lance, this poses an interesting question for me. I've changed out my tail/brake light to LED to reduce the electrical load on my bike. Plan to do the same with the front running lights/blinkers. Am I actually causing my R/R more potential damage rather than helping my electrical system out?
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 16 (permalink) Old 07-29-2009, 11:15 PM
Kinda. Most folks add LED's to save power so they can runs something else...like driving lights or heated gear. But I would not go as far to say that you are "causing your R/R more potential damage". If you have relocated your R/R you have already taken a step to eliminate "potential damage"...
Perhaps you should use that extra power for something cool eh?
post #6 of 16 (permalink) Old 07-30-2009, 02:16 AM
Vulcan Traitor ;)
Send a message via Yahoo to Keemez
I swapped out all my bulbs with LEDs too and tossed in an 80/100w headlight bulb. I still have the ole wet cell battery; haven't checked water levels in it since last fall (?) and my VM still shows anywhere from 13-14 in ridiing conditions. The only time I see it dip below 12.5 is at idle and when the cooling fan comes on. Once this battery goes tango uniform I'll toss in the AGM that I got last fall.
Keemez is offline
post #7 of 16 (permalink) Old 07-30-2009, 03:22 AM
The Professor
lance328's Avatar
As KM said, If you have relocted your R/R it will incerase the life span. The less power the system needs the more the R/R has to bleed off to ground and the hotter it will get.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 16 (permalink) Old 07-30-2009, 06:43 AM
Newb with a Bullet!
krebsne's Avatar
This has been an interesting thread. I thought I needed to go LED so more power would go to charging the battery. That's my concern. If I'm just damaging my R/R by reducing the load then what's the point? Might as well stick w/ conventional lighting.
Current VN: 03 VN1600A
Past VNs: 92 VN750A, 98 VN1500A
Future VN: 94/97 VN1500A basketcase/bobber
krebsne is offline
post #9 of 16 (permalink) Old 07-30-2009, 09:19 AM
fergy's Avatar
Just FYI, you don't want to go more than a couple weeks especially in this time of year without checking your water level in the battery! If the battery fails, it can take the rest of your army with it sometimes. You especially need an AGM battery!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 16 (permalink) Old 07-30-2009, 04:59 PM Thread Starter
Ratbiker
Good responses. I'll definitely add an air horn if it's helping my bike out.
Cobra slashcuts
Gel cell battery
11" MDI shocks
Bike flat blacked
Custom mirrors
Fitted cafe fairing
