blowing fuses while shifting... between first and second - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-28-2009, 09:57 PM Thread Starter
Clint '89
ourselfish's Avatar
I blew two again today replaced the entire wiring harness over a month ago. I checked the entire thing before installation for splits in the wires or open connections, My grounds are tight.
Blew it reversing down an alley way looking for parking, it was sunny today
Taking it out of gear as I parked.
While shifting from up from first.
ourselfish is offline
post #2 of 4 (permalink) Old 07-28-2009, 10:00 PM
The problem is centered around the nuetral switch. Are you able to disconnect the nuetral switch? If possible, do so and see if it helps.
post #3 of 4 (permalink) Old 07-29-2009, 04:53 AM Thread Starter
Clint '89
ourselfish's Avatar
thank you NR
post #4 of 4 (permalink) Old 07-29-2009, 09:07 AM
I take it that it's the main fuse that's blowing?
