Pros and cons of Lead-antimony and - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-27-2009, 12:49 AM Thread Starter
Clint '89
ourselfish's Avatar
Compared with flooded lead-acid cells, VRLA batteries offer several advantages. The battery can be mounted in any position, since the valves only operate on over pressure faults. Since the battery system is designed to be recombinant and eliminate the emission of gases on overcharge, room ventilation requirements are reduced and no acid fume is emitted during normal operation. The volume of free electrolyte that could be released on damage to the case or venting is very small. There is no need (nor possibility) to check the level of electrolyte or to top up water lost due to electrolysis, reducing inspection and maintenance.
ourselfish is offline
post #2 of 2 (permalink) Old 07-27-2009, 09:50 AM
cglennon's Avatar
Also, absorbent glass mat (AGM) is a class of VRLA battery and the type which works best with the VN750!
Chris Glennon - Portland, OR
cglennon is offline
