Bad stator wires? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-26-2009, 08:30 PM Thread Starter
Bad stator wires?
I have a Vulcan 750. The stator went out on it. Without going through a long story, I removed the engine and replaced it. I also replaced the voltage regulator. I fired the bike up and went on a short 15 mile trip. When I got back, I noticed trace amounts of smoke coming from the stator wires and a little bit of burned insulation. My first thought was that it was up against something hot. After further evaluation, I realized that the heat was coming from the wires. All parts that I used were brand new. Ive retraced my steps a 100 times and I cant find anything wrong, Does anyone know whats going on? PLEASE HELP!!!
kkmcleod750 is offline
post #2 of 8 (permalink) Old 07-26-2009, 08:42 PM
The Professor
lance328's Avatar
What kind of battery do you have and how old is it?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 8 (permalink) Old 07-26-2009, 08:48 PM Thread Starter
The battery is a super start. I bought it brand new a month ago. I killed it a couple of times before realizing the stator was bad. Its currently not charged. My plan was to jump the bike off, ride it for a while and let the stator charge it.
post #4 of 8 (permalink) Old 07-26-2009, 09:43 PM
The Professor
lance328's Avatar
You must charge the battery before you start the bike, a low or bad battery can fry the stator. Is it a flooded lead acid or an agm mf battery?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 8 (permalink) Old 07-26-2009, 09:51 PM
And for the best charge, use low amps....around 1.5 or 2.
Lower amperage for a longer time gives a much better charge than higher amps for a short time.
post #6 of 8 (permalink) Old 07-26-2009, 09:55 PM Thread Starter
Its lead. It looks like acid has been dripping on the regulator, I fixed that. Doesnt look like any major damage was done. But the battery was completley dead when I installed it. I jumped it off with a car. I got it slow-charging right now, I hope it didnt cause any damage to the stator. I figured the concept was the same as a car, the alternator will charge the battery, I guess I was wrong.
post #7 of 8 (permalink) Old 07-26-2009, 10:02 PM
The Professor
lance328's Avatar
With an alternator it is not a problem, with a stator it is.
Get a good MF AGM BATTERY and save yourself problems in the future.
Battery
http://cgi.ebay.com/ebaymotors/Deka-...ehicleQ5fParts
Once you get the bike running, test the battery voltage @ 4000 rpm to make sure you are charging.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 8 (permalink) Old 07-26-2009, 11:39 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
[QUOTE=lance328;108506]
QUOTE]
Yes Do........It's been between 103 - 112 deg here for the last 2 weeks.
I went out the other day to take the bike on a short trip after it's been sitting for a week and a half.
It started as soon as I hit the Button.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
