Help .Neutral Light on - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-25-2009, 09:39 PM Thread Starter
Help ..My wife was practicing with the 2001 VN750, tapped a curb with the right side, bending the right foot peg, and foot brake up and back (Not hurt). Now the Neutral light is constantly on. TheBike is still driveable and the rear brake activates the stop light (If you push hard), but the the neutral light is on constantly wheither in gear or not. Suggestions of what I should look for ? Any suggestions of what I should look for to fix this part of the problem? Where is the neutral switch ? Thanks
Vtvintner is offline
post #2 of 4 (permalink) Old 07-26-2009, 09:24 AM
Crobins365's Avatar
Unless my memory has failed me this morning (a definite possibility - half a cup of coffee so far), there's a light green wire running under the engine block that signals the bike being in neutral. Comes off the back of the block and inserts into the wiring harness, I believe. Check to see the status of that. Not sure why her pinging the curb would affect that, but worth a check. Also check the switch on the left hand controls - it's underneath the control and the clutch lever - when at rest- pushes against the pins to signal the pilot box.
Hopefully someone with more coffee can jump in and be more articulate! But this should be a straightforward fix.
C
Crobins365 is offline
post #3 of 4 (permalink) Old 07-26-2009, 02:04 PM
Search Goddess
Dianna's Avatar
I think it was more then a tap if it bent the brake pedal and foot peg but.. since the bike is still driveable I agree (I've got 3/4 cup of coffee in me!)
The neutral switch is located on the lower right hand rear surface of the crankcase below the engine mounting (Page 330 if you have a Clymers Manual)
Sure sounds like the area that took the hit
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 4 (permalink) Old 07-26-2009, 03:19 PM
Love My Baby
rubyrick's Avatar
Vtvintner, check to see if the right footbrake is touching anything on the bottom (or anywhere else for that matter). If it is, bend it back away or you may feel some annoying vibrations. Happened to me and it was cured with the re-bend.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
