Opinions please - Starting issues again - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-18-2009, 06:27 PM Thread Starter
VulcanCruizer's Avatar
Hello all,
It's been a while but I had posted before that my bike felt like the battery kept going dead. Even when I got my sealed battery it worked fine but every now and again it would hesitate to turn over. Strangely enough it got better for a few weeks and then all of a sudden the bike won't start as of today. I figured it was the battery since it was sitting for about a week and prior to then it was about a month (darn New England rain) before I rode it that time. I put the charger on and when it was charged I tried again. "Click" is all I heard. I then proceeded to troubleshoot the electrical system. Battery, Ok. Relay, Ok. Power all the way to the starter, Ok. I then removed the terminal on the starter and cleaned it thoroughly, as I did a few months ago, and put it back together with dielectric grease. Tried to start the bike. Nothing. My educated guess is telling me that the starter is dead but maybe someone has seen this before and has a trick up their sleeve? lol.
My unfortunate unemployment issues are going to keep me from purchasing a new or even rebuilt starter but hopefully I can pull this one out and clean it or replace the internals for cheap.
1989 VN750
Purchased 4/26/2008 @ 27,320 Mi
Upgrades:
Travelcade Mustang Seat
SpitFire Tinted Quick Release Windshield
Degoat, Drilled & Jetted
Leather Saddle Bags
Johar Signature Grips
Deka ETX15L Powersports AGM Battery
NGK DPR7EIX-9
Upcoming:
1991 VN750 Project Bike
Purchased 4/30/2011 @ 31,970 Mi
VulcanCruizer is offline
post #2 of 8 (permalink) Old 07-18-2009, 06:42 PM
The Professor
lance328's Avatar
Check the Battery,frame and engine grounds, remove and clean them. If you take a jumper cable from battery + lead and touch the starter lug you can check the starter.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 8 (permalink) Old 07-19-2009, 03:02 PM
Calif Rider
weh44att's Avatar
The new AGM battery maybe bad. May need to check at the store you bought it or a parts store to see if it really has enough amps to crank the engine. It may read good but not enough CCA to turn the engine over.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 8 (permalink) Old 07-19-2009, 03:12 PM Thread Starter
All above has been done as of today. Confirmed 12v all the way from battery to starter and grounded to frame.
Seems the starter is hosed. Anyone know a cross reference of the starters across Vulcans? I'm hoping there are a few different years/models I can use.
1989 VN750
Upgrades:
Leather Saddle Bags
NGK DPR7EIX-9
Upcoming:
post #5 of 8 (permalink) Old 07-19-2009, 04:01 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
I'd try taking apart the starter and Cleaning & Lubing it. Then check it outside of the bike and see how it turns.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #6 of 8 (permalink) Old 07-20-2009, 02:51 PM Thread Starter
I was thinking that as well so I took it apart and I couldn't believe how crudded up it was. The Commutator was black and 2 of the brushes were stuck in the holders. I cleaned and lubed everything, put it back together and then installed it in the bike and she started first press of the button.
The whole project took me about an hour. For not having cleaning a starter before I'd say it was pretty easy.
Thanks for all the suggestions.
1989 VN750
Upgrades:
Leather Saddle Bags
NGK DPR7EIX-9
Upcoming:
post #7 of 8 (permalink) Old 07-20-2009, 09:29 PM
Love My Baby
rubyrick's Avatar
Good work! I'll remember that one when my starter goes. Thanks for posting...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #8 of 8 (permalink) Old 07-21-2009, 12:19 PM
fergy's Avatar
That's great news! Its easy to take for granted the starter motor, but it is in a position to gather all the crud thrown up by the front tire, kind of a "first responder" to all the grime. Glad you were able to bring it back to life. It's also great to have this information on the forum!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
