Plug Wire source - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-15-2009, 03:18 PM Thread Starter
electrum's Avatar
Plug Wire source
i ordered new NGK plugs and the plug connectors from DennisKirk that were mentioned in the Verses.. but i'm having no luck finding 6foot of 8mm yellow/red non-resistor plug wire.
does anybody have a source/link where i can buy just a length of plug wire i can cut up and use?
or am i just going to have to buy a pre-made set and cut the ends off?
if so.. most sets are resistor wire.. is it going to make much difference if i get a set of resistor wires? i'm thinking of the Accel 8mm high performance wire sets.
96 Vulcan 750
electrum is offline
post #2 of 4 (permalink) Old 07-15-2009, 06:03 PM
Calif Rider
weh44att's Avatar
Just looled it up SUMMIT racing is one place to get the wire. Gooble it and there are a lot of places. You mit even try your nearest auto store.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 4 (permalink) Old 07-15-2009, 06:07 PM Thread Starter
electrum's Avatar
i looked all over summit racings page and didn't see any wire that wasn't in a 'set'.
do you have a particular part number? i probably just missed it.
and i've been to all the big stores and none of them have wire that isn't already in a set.. NAPA, Checker, AutoZone, Pep Boys...
96 Vulcan 750
electrum is offline
post #4 of 4 (permalink) Old 07-15-2009, 06:28 PM
I don't know about colored wire but tractor supply carries non resistor wire sets for old farm tractors that are on the cheap
