Battery Life Under Heavy Use... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-13-2009, 04:13 AM Thread Starter
SyntaxJO's Avatar
I bought a brand new battery when I bought the used bike. I've been working on her heavily over the past weeks and I have used the hell out of the battery. What seems to be happening is that it dies rather quickly. My suspicion is that I'm draining it quickly because of the times when I would turn the starter over and the bike would not start up as I was fixing it - and I would crank it and crank it and crank it. Other times I would forget to turn the key off - leaving the headlight on for 5 - 10 minutes. Since it's initial charge I have charged the battery 2 times in addition to the charge I'm giving it now - 3 charges over the past.... month at the least.
Is something else draining my battery? or is it just because in between charges I've coincidentally left the headlamp on for 5 - 10 minutes and been cranking the starter heavily. How long should a battery last under heavy "non motor running" usage?
-J.O'Ly.
'95 Vucan 750 -- VN750
SyntaxJO is offline
post #2 of 4 (permalink) Old 07-13-2009, 04:49 AM
The Professor
lance328's Avatar
They will drain down very quickly in your situations, a HL on for ten minutes will drop the battery down to 55-60% state of charge which is not enough to start the bike.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 07-13-2009, 09:54 AM
fergy's Avatar
Yep, these little batteries are made to give it all they got to crank the bike and get her started, then you need to ride for a while to get it charged back up for the next start. Under normal riding/starting conditions, the AGM battery should last 2-3 years. If you're doing a lot of work on the bike, I would probably purchase a new AGM for when you have it fixed and running good, but continue to use the old one while you do all the work. I don't know how the gel batteries take to being discharged down so low and then recharged often, but I know the little wet cell batteries don't last long doing this. Just my .02!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 4 (permalink) Old 07-13-2009, 05:21 PM Thread Starter
SyntaxJO's Avatar
Thanks guys - I appreciate it.
-J.O'Ly.
SyntaxJO is offline
