New Silver Star bulb installed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 07-12-2009, 11:55 PM Thread Starter
Just put it in today, wanted to do this for a while. Checked it out tonight and I like it. Really is much brighter.
I originally wanted to check my tach bulbs (right side out) and had everything apart, ended up the bulb wasn't in properly.
post #2 of 12 (permalink) Old 07-13-2009, 10:54 AM
fergy's Avatar
The silverstar is a great, bright bulb. I'm sure you can see a difference! They are worth the money.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 12 (permalink) Old 07-13-2009, 08:13 PM
cm4cm5's Avatar
what are the numbers for the silverstar bulb, ive been planning this myself. just havent gotten around to it. besides i dont do that mush night riding enyway.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #4 of 12 (permalink) Old 07-13-2009, 09:33 PM
Lebanon, NJ
Hiker's Avatar
Sylvania H4ST 3 BP 6 Silver Star High Performance Halogen Headlight Bulb is the one I use.
http://www.amazon.com/Sylvania-H4ST-...RQ28S5NW5THM2P
Hiker is offline
post #5 of 12 (permalink) Old 07-13-2009, 11:29 PM
Benjammin'
BSkaggs513's Avatar
Does anyone know if the halogen bulb uses less current than the OEM? Since we are looking for less current consuming devices because of the achillies heel charging system, I wonder if this bulb helps or hurts.
I know, I know, you can't put a price on safety
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #6 of 12 (permalink) Old 07-13-2009, 11:36 PM
You have to go by the wattage on the bulb. The original bulb is also a halogen bulb. Original bulbs are ussually 60/55.
post #7 of 12 (permalink) Old 08-01-2009, 09:06 PM
Silverstar now has an ultra that supposedly puts out 15% more light than the original silverstar. I just bought a pair on ebay. Look up silverstar ultra and it will link you to the sylvania web site.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 12 (permalink) Old 08-02-2009, 10:37 AM
cglennon's Avatar
I installed SilverStars last year and am very happy with the results. However, I would suggest that you buy them in the double pack, because they do not last as long as regular halogen bulbs. Luckily SilverStar runs a mail in rebate program just about every year, but only on the double pack (google silverstar rebate). The other bulb that is pretty good is PIAA which puts out more light than the SilverStar, but also cost more (even on eBay).
Chris Glennon - Portland, OR
cglennon is offline
post #9 of 12 (permalink) Old 08-02-2009, 10:54 AM
dirtrack650's Avatar
Anyone run the Silverstar MC bulb? They cost more but are designed to take the vibes.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #10 of 12 (permalink) Old 08-02-2009, 03:04 PM
Lebanon, NJ
Hiker's Avatar
I...
DT
I believe the one I use and linked to above is the MC one.
Hiker is offline
