Volt meter Guage Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-05-2009, 06:40 PM Thread Starter
tickman's Avatar
I not the best in wiring so was wondering if I can wire a volt gauge meter on my bike, black wire to ground and red wire in line fuse 5 amp to the fuse box and get a accurate reading while riding.
tickman is offline
post #2 of 6 (permalink) Old 07-06-2009, 07:21 AM
kontiki's Avatar
Yes, that will work fine for you. There are some arguments for getting as close to the battery as you can for a more accurate charging voltage measurement but a voltmeter is a high impedence device so it doesn't really matter for your purposes.
If your wiring is in good shape you should not see much of a voltage drop anywhere you measure it. If you see a significant difference (near a volt or even more?) anywhere it then I'd be worried about a bad connection or poor ground somewhere.
1996 Vulcan 750
1980 XJ650 Maxim
kontiki is offline
post #3 of 6 (permalink) Old 07-06-2009, 08:16 AM
750Doug's Avatar
Here's an easy to read/use wiring drawing if you want to use it. There are a few others floating around the forums as well-
VM wiring
750Doug is offline
post #4 of 6 (permalink) Old 07-10-2009, 04:55 PM Thread Starter
tickman's Avatar
Whats the purpose of a relay if your splicing in the juction box
tickman is offline
post #5 of 6 (permalink) Old 07-10-2009, 07:59 PM
The Professor
lance328's Avatar
You need a Key on power sorce to to activate the relay. Once the relay is activated it will let power flow from the main source.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 6 (permalink) Old 07-10-2009, 11:03 PM
cglennon's Avatar
If you're not ready to wire up a relay yourself, or don't have a garage/shop (like me), then consider a premade one. Here is one I purchased for my heated grips and volt gauge. Very high quality and about 5 minutes to install, thanks to Posi-Lock connectors.
Available from Eastern Beaver Company (in Japan) for about $25. Can be used with heated grips or any other accessory. They make other versions as well.
Specifications:
- 20A Panasonic Relay and socket
- VOX wire covering
- 2 fuses included of your choice from 5A - 15A
- switching wire 24" (60 cm)
- grip leads 24" (60 cm) (attached my volt meter as well)
- relay located 9" (23 cm) from battery POS
- ground lead 15" (38 cm) from battery NEG
- 4 cable ties included
- Sumitube shrinktube included for strain relief on the grip heater wires
- extra sheathing for wire (Symtec yellow wire)
Chris Glennon - Portland, OR
cglennon is online now
