1994 VN750 Charging Troubles - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 06-29-2009, 03:10 PM Thread Starter
When I pull the headlight and taillight fuses, I get a 12.6v. With all the fuses in it charges about 11.5 and runs the battery dead after a few miles. Wiggled the junction box cables and it started charging better for a moment. Anyone dealt with this before??? Thanks Martin
martin42211 is offline
post #2 of 13 (permalink) Old 06-29-2009, 04:17 PM
x-dirt
i would clean all the connections and apply some dialectic grease. allthough you may have a short somewhere. hang in there, there are some good electrical guys here that will help.
dutter is offline
post #3 of 13 (permalink) Old 07-01-2009, 10:51 PM Thread Starter
were can I buy this dialectic grease?
post #4 of 13 (permalink) Old 07-01-2009, 10:54 PM
phurp's Avatar
any auto parts store will have it.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #5 of 13 (permalink) Old 07-02-2009, 08:24 PM
Concert connoisseur
wib714's Avatar
autozone! what can I say I am a devoted autozone customer. I will drive 10 miles past an advanced auto and 100 past a napa to buy my stuff at autozone!
And no I dont work there, I work for cvs pharmacy.
and I will drive a 100 miles past a walgreens to shop at cvs. LOL
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 13 (permalink) Old 07-02-2009, 09:29 PM
The Professor
lance328's Avatar
Check the back side of your JB and see if you have acid damage.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 13 (permalink) Old 07-05-2009, 07:33 PM Thread Starter
Thumbs up
way yes ,yes it does!
post #8 of 13 (permalink) Old 07-05-2009, 08:55 PM
The Professor
lance328's Avatar
You need to replace the JB, there is one in the link below it will fit all years. Replace your battery with a good MF AGM battery in the link below. Check your R/R connector for acid damage as well, located under the battery box.
JB
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Battery
http://cgi.ebay.com/ebaymotors/Deka-...4506.m20.l1116
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 13 (permalink) Old 07-09-2009, 04:30 PM Thread Starter
replace the JB, No help , Replace battery with a good MF.!!!!!!! RUN great I get a 12.6v to
12.9 at 3000 RPM
post #10 of 13 (permalink) Old 07-09-2009, 08:47 PM
rider
global_recon's Avatar
hello martin.
unfortunately, the charging system on our favorite motorcycle is a bit of a sore point. given that you've replaced the junction box and the battery, the next two suspects are the regulator/rectifier (in its stock location, it's underneath the battery box) or the stator. you'll need to a get a multimeter (radio shack or another electronics store has these) and start taking some electrical readings to determine where the problem lies.
there's a fault finding guide here http://www.electrosport.com/technica...ding-guide.php which will help you track down the problem. your hope would be that it's a problem with the r/r as it's fairly easy to replace. the stator unfortunately requires completely removing the engine (or at least tilting it at an angle) so that you have enough clearance to take the engine cover off and access the stator.
do some searches on this site. you'll come across a lot of info regarding the charging system. here's wishing it's an easy fix for you!
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
