Tach and Fuel Gauge quit, then worked for next ride - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-24-2009, 04:14 PM Thread Starter
My SO took the 93 Vulcan 750 to work one day. On the way home (open road) she said the fuel gauge dropped to E and the tach stopped working, and she also reported it was running rough. Made it home, but still missing and running rough, both gauges dead. When I started it up 5 minutes later, both gauges worked fine and it did not seem to have any problem running.
Any ideas?
Thanks
Jim
93 VN750
jeshultz is offline
post #2 of 3 (permalink) Old 06-24-2009, 04:24 PM
fergy's Avatar
The tach is wired from the front coil, so if it was running rough when it happened, it sounds like you lost something on the front coil during that time. Maybe wires are loose, or frayed, rubbing on something under the tank. Don't know off hand what that has to do with the fuel gauge, except for the fact that the wiring for it is also under the tank... Seems like you need to snoop around under there and see what's up!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 3 (permalink) Old 06-25-2009, 12:21 PM
Now what
Ironman's Avatar
Make sure all the battery connections are still tight.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
