New R/R Relocated - Simple! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-15-2009, 10:54 PM Thread Starter
ExNewbie..Still Learnin'!
rsawyer's Avatar
Well, finally got a new R/R (thanks or the E-Bay steer Lance ) and relocated per Fergy's signature procedure( thanks Fergy ) although left my old one one in place.
Only exception to Fergy's directions was I used all stainless steel hardware with an aluminum strap bar to prevent corrosion. A little more expensive but inhibiting rust was my main concern.
I also backfilled the white connection plug wiring with dielectric grease in each opening to prevent water entry. Hopefully it will work but will likely need to be done on a regular basis. Figured, can't hurt, might help.
Total cost: R/R - $89, SS Hardware - $6, Peace of Mind - Priceless.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #2 of 14 (permalink) Old 06-15-2009, 11:00 PM
I'm looking for a piece of heat sink to use for relocating the r/r.
post #3 of 14 (permalink) Old 06-15-2009, 11:46 PM
flitecontrol's Avatar
Would a piece of flat aluminum about 1/8" thick fill the bill? If so, PM me.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 14 (permalink) Old 06-15-2009, 11:49 PM
Go to your local hardware and buy some 1/8" flat aluminum about two inches wide it comes in 4 or 5 foot sticks and is as handy as any thing you can have in your garage,I use it to make brackets and hangers.You can clamp it down in a vice and bend it by hand and it is easy to cut.stack up two or three pieces up and bolt it to back of your R/R and, Instant heat sink, and a very good one at that.you will find all kinds of neat uses for it after you get it and it won't last long,also good stuff to relocate turn signals with.
post #5 of 14 (permalink) Old 06-15-2009, 11:51 PM
he's fast
post #6 of 14 (permalink) Old 06-15-2009, 11:55 PM
he's fast
Not very often!
"Black Beauty"
Old Blue
post #7 of 14 (permalink) Old 06-16-2009, 12:03 AM
Well, a while back, I saw a peice of aluminum about the right width with ribbed back. The old age kicked in and I can't member where I saw it. I am going to check at the local radio shack. If I could only member where it was, dang-it!!!! I'm going to call my bro too. I will let you know flitecontrol if I will need material from you thanx.
If I find what I saw I will post a picture. It will work great for this.
post #8 of 14 (permalink) Old 06-16-2009, 12:06 AM
Scrap yard/junk yard/metal recycler is also a good source for this stuff. Usually happy to swap out aluminum cans for similar amount of flat stock.
"Black Beauty"
Old Blue
post #9 of 14 (permalink) Old 06-16-2009, 12:35 AM
junked out computers have some pretty good heat sinks on the processors too.
post #10 of 14 (permalink) Old 06-16-2009, 12:40 AM
Just a heads up offered here. You are right about aluminum not rusting, BUT it does corrode. I have pieces of aluminum in my scrap pile with aluminum and steel bolts threaded in, and virtually welded in place by electrolosis between dis-similar metals, (the AL bolts are a slightly different alloy than the Al strap metal). Aluminum will develop a white dusty corroded surface after a lengthy exposure to moisture and weather.
Stainless steel is probably more resistant than either mild or high carbon steel in contact with aluminum. However I would still use some anti-seize compound such as copper-cote or silver-cote, where the two metals touch, as well as between the reg/rec and the aluminum strap.
