Turn Signal Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-15-2009, 10:09 PM Thread Starter
My turn signal are working, However the display indicator light just started flashing rapidly for some unknown reason.
Just wondering if this is somthing that could be a potential electrical problem or a common problem that can be fixed easily.
John Brisson is offline
post #2 of 4 (permalink) Old 06-15-2009, 11:03 PM
Love My Baby
rubyrick's Avatar
Usually this happens when one bulb is burned out, or if you have LED bulbs in the front OR rear only, or didn't change the flasher relay when you switched all 4 turns to LED.
Are your front running lights working properly? You said the turn signals were, but the fronts are running AND turn lights.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #3 of 4 (permalink) Old 06-15-2009, 11:33 PM Thread Starter
I will check the headlights in the morning. I usually ride during the day so it is possible the headlight is burned out and didn't even notice. I will feel like a complete moron if thats all it is.
post #4 of 4 (permalink) Old 06-15-2009, 11:37 PM
Love My Baby
rubyrick's Avatar
John, check the front RUNNING lights, not the headlight. The headlight can't make the turn signal indicator blink fast.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
