VN750 R/R replacement specifics - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-13-2009, 12:35 AM Thread Starter
Can anyone tell me if the R/Rs are model/year specific? If I need one for my '93 750 can I use one from a '92 or '94?
Johnny Appleseed is offline
post #2 of 6 (permalink) Old 06-13-2009, 12:58 AM
Jace Bror's Avatar
They are pretty much all the same. I got a good deal on one from these guys. http://www.psep.biz/store/kawasaki_m...regulators.htm
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #3 of 6 (permalink) Old 06-14-2009, 01:34 AM
Well Johnny A, I would have agreed with Jace before I checked out his link to Kawasaki Regulators. I have been under the impression that the r/r on the vn750 has a 6 pin electrical connector on a wire pigtail, and interchangable between all model years. This link shows 3 different r/r models, two with no pigtail (including your `93 model), just a direct 6 pin plug on the r/r body. The third has a 4 pin pigtail and 2 separate, individual wires to plug in. They are specified for different years, and two have a different spacing for mounting holes, while third does not specify at all.
Check out Electrosport`s Model ESR 260. http://www.electrosport.com/products...detail-585.php
It is $20 more, but has the pigtail mounted 6 pin connector, and is specified to fit all vn700/750 models from 1985 to 2006. If you are going to do a r/r relocation to the frame by the left foot peg for better cooling, when you replace it, you may need the little bit extra wiring included in the pigtail. The reg/rect in jace`s link may be just as reliable, when installed, as Electrosports is. So take a look at yours to see if it has a pigtail connector, and decide which one you want or need.
post #4 of 6 (permalink) Old 06-14-2009, 01:46 AM Thread Starter
Thanks Jace and OHC! I appreciate the info.
So Jace, what year is yours?
post #5 of 6 (permalink) Old 06-15-2009, 12:59 AM
The part number for '92 and '93 is the same: 21066-1055. The part number for '94 is 21066-1089. My guess is that that electrically all year models are the same and the differences are mechanical.
pappa is offline
post #6 of 6 (permalink) Old 06-15-2009, 10:37 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Here's one that LAnce328 found on EBAY for me. http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
As close to the original as I have found and made in Japan. Installed (relocated) this weekend. Seems to be excellent quality. I guess time will tell. I have an '89 but believe yours should be similar. Think they changed in '94. Good luck wih the changeout. Piece of cake, really.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
