Has anyone seen this before? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-09-2009, 06:07 PM Thread Starter
Alatri's Avatar
Lost w/ what going on w/ these random splice wires???
https://www.vn750.com/photopost/showp...0&limit=recent
Guy before me did a number on these wires.
What should i do?,
where to start?
Alatri is offline
post #2 of 10 (permalink) Old 06-09-2009, 06:21 PM
93VN750's Avatar
I would get some correct gauge wire in the correct colors and splice in using butt splices and/or heat shrink tube and/or solder to "remake" the correct harness. Then tie it up correctly to eliminate future problems.
The shop manual has all the color coding for every circuit.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 10 (permalink) Old 06-09-2009, 06:53 PM
Crobins365's Avatar
Is that a lamp cord in there?!? The big brown thing?? x2 on Jon's suggestion...
C
Crobins365 is offline
post #4 of 10 (permalink) Old 06-09-2009, 09:24 PM
93VN750's Avatar
Yup, that's good old zip cord, primitive at best.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #5 of 10 (permalink) Old 06-09-2009, 09:24 PM
750Doug's Avatar
It looks like a lamp cord or one of the cheap-o extension cords.
I swear we should start a new forum just for PO hack jobs...
750Doug is offline
post #6 of 10 (permalink) Old 06-09-2009, 09:48 PM
You mention a black box in the tool compartment.
Does the brake light flash on & off a few times when the brake is first applied?
If so, could be a brake light modulator. Otherwise...???... don't know w/o a pic.
post #7 of 10 (permalink) Old 06-10-2009, 02:58 AM Thread Starter
Alatri's Avatar
This is some sort of rigged up lamp cord,
One end is a type of plug, and the other seems to be meant to be attached to the battery
Maybe someone can tell what it's for, could it be a crackheaded battery tender?
https://www.vn750.com/photopost/showp...5&limit=recent
https://www.vn750.com/photopost/showp...6&limit=recent
Also, what could be the purpose of this, This is where all those wire go, not sure what it is, does it belong somewhere else???
My other Vulcan is back east, so can't remeber if this thing was mounted somewhere else???
It's in the back of seat compartment.
https://www.vn750.com/photopost/showp...7&limit=recent
http://pic80.picturetrail.com/VOL100.../366682059.jpg
Haven't put any power to the bike yet, Dude disconnected many plugs to remove the carbs, if you look at the other picture in the album,
" Another Vulcan, This one gonna hurt. " , it show the guy i got it from took vents, coolant hose, plastics, and everything else that didn't need to come off,
so far i am trying to clean it up, look all over, see what exactly is going on.
Alatri is offline
post #8 of 10 (permalink) Old 06-10-2009, 10:46 AM
Search Goddess
Dianna's Avatar
Ahhh now the plug in the toolbox looks like something..
It looks like a quick connect for a charger or battery tender.. almost..
Usually the quick connect has a male and female connect but there are some with just two female
http://www.cruisercustomizing.com/de...pping&shopping
It's just not the usual one used by motorcycles
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #9 of 10 (permalink) Old 06-12-2009, 04:09 AM Thread Starter
Alatri's Avatar
Any clue what the black box w/ those wire from the lights of the rear of the bike, the wires got sliced and then sent to the box in the seat back compartment???
Alatri is offline
post #10 of 10 (permalink) Old 06-12-2009, 05:55 AM
750Doug's Avatar
When I clicked on that link, this is the System error message I got: (read 'em all for a laugh)
Hmmmm...you were probably looking for a page or file that either:
A. You typed incorrectly
B. Doesn't exist
C. Fell off the planet
D. You don't have permission to view (ask nice)
E. Was eaten by the Ravenous Blugbatter Beast of Traal
F. Was hacked
G. Was erased
H. Was renamed
I. Was moved
J. Was abandoned
K. Ran away from a killer bunny
L. Went AWOL
M. Was talked to in a harsh tone and sulked away in a dark corner of the server
N. Is on vacation
O. Is sleeping
P. Broke free of it's html shackles
Q. Is playing hooky
R. Called in sick
S. Is in jail
T. Was bumped off by the Windows Mafia
U. Took a one way ticket to the Recycle Bin
V. Is corrupt (probably on the take, if you know what I mean)
W. Succumbed to a virus, most likely the common cold
X. Got a better offer over at a bicycle website
Y. This page left intentionally blank
Z. <insert your own reason here>
Anyhow, if any of the above happened, you are better off visiting our Homepage.
Chances are you'll find something worth looking at.
750Doug is offline
