possible r/r problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-02-2009, 08:30 PM Thread Starter
Okay, when I start up, the volts vary up and down. Some times it goes up to 16 or more volts. After a few miles of riding the volt stabilize to normal. I have an r/r on order.
Do ya'll thenk that the r/r is the problem?
This problem is on the vulcan.
post #2 of 12 (permalink) Old 06-02-2009, 08:35 PM
I noticed my volts moved around a bit, as I had a digital readout I could watch it flip from 13.7 to 14.1 then sometimes bounce to 15.3 or something. Even at a steady idle it toggle between 14.2-14.3-14.4.
It did seem to slow up as the bike warmed up, but I think what you have to keep an eye on is that it does not go below 13.0 volts often and never hits under 12.6 unless you are starting the bike.
If you see it fluctuate from 13.6 to 11.8 while riding, you might have a problem.
post #3 of 12 (permalink) Old 06-02-2009, 08:41 PM Thread Starter
The first time it did it it burned out my head light.
I am also going to relocate too.
post #4 of 12 (permalink) Old 06-03-2009, 10:42 AM
darrelc5's Avatar
I had this same problem and found the negative terminal on the battery was loose. If you find this, add a thin flat washer beneath the ring terminal of the battery cable as it will keep vibration from loosening the battery bolt.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #5 of 12 (permalink) Old 06-03-2009, 11:07 AM
I agree. Check connection from r/r to battery negative terminal. If that is good, the monitoring connection of the r/r may be at fault. I have no idea where it connects to the harness, but if you measure resistance from the r/r monitor pin to the battery positive terminal with ignition on, it should be close to 0.
pappa is offline
post #6 of 12 (permalink) Old 06-03-2009, 01:44 PM
waggy1236's Avatar
Mine did that, and after ordering new R/R, I tested further and found when I connected positive side of voltmeter directly to the battery, it reads solid as a rock (12.5 and 14.5 ). Oh well, a spare R/R is not such a bad thing.
57 years experience,Zero accidents. Starting with 1947 Indian Chief. Now VN750 , V65 Magna, Burgman scooter.
waggy1236 is offline
post #7 of 12 (permalink) Old 06-03-2009, 05:40 PM Thread Starter
Thanx I will check the connections. When the r/r gets here I will still do the r/r relocation.
post #8 of 12 (permalink) Old 06-10-2009, 07:08 AM
750Doug's Avatar
So what's the word NR? Have you done anything or installed the new R/R yet? Problem found and solved?
750Doug is offline
post #9 of 12 (permalink) Old 06-10-2009, 10:33 AM Thread Starter
I have the new r/r and now I am looking for a piece of aluminum to do the r/r relocation. I will post results.
post #10 of 12 (permalink) Old 07-05-2009, 11:52 AM Thread Starter
I got the r/r relocated. Did not find the finned heat sink that I wanted.
The voltage runs lower than before. High 12's and it goes up when load is applied.
