LED turn signals? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-29-2009, 01:12 PM Thread Starter
LED turn signals?
Hey everyone,
Looking to replace my turn signals with LEDs. Not just those little LED bulbs, but one of those boards that have LEDs on them or a complete assembly with LEDS built in.
I found these: http://clearalternatives.com/Merchan...Code=KCRUISERS
Anyone have those? Do they fit our bikes? (not feeling the clear lens though)
Or is there a LED board that fits into the factory turn signals?
I tired searching, but the word "LED" is too short and I can't search for it
G_Loc is offline
post #2 of 7 (permalink) Old 05-29-2009, 01:42 PM
dirtrack650's Avatar
I like LED's but you need to know they are only super bright when you look directly at them. The regular 1157 bulb is much more visible to the side of our blinkers than LED's. If you find a LED board that has LED's pointing to the side of the blinker lens as well as to the face, let me know, I'll buy it.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 7 (permalink) Old 05-29-2009, 01:46 PM
Newb with a Bullet!
krebsne's Avatar
Good point. Also the main advantage to LEDs as I understand it is lower power consumption. I've been told the turn signals are used so little that there is negligable benefit to swapping them for LEDs from the power saving stand point.
You're better to address the tail light if I understand correctly. It runs all the time and draws constantly.
What are your aims in putting on LEDs? Change the look of the bike? Be more visible to others? Lower your power draw? It always helps to know what you're trying to accomplish.
krebsne is offline
post #4 of 7 (permalink) Old 05-29-2009, 03:20 PM Thread Starter
Mostly better visibility (wouldn't mind new turn signals though). Already have the LED tail light and its noticeably brighter than the incandescent bulbs, so I was hoping for the same with the turn signals.
You're right about power consumption with the brake light. Before the headlight would dim a bit when braking, now it doesn't dim at all.
G_Loc is offline
post #5 of 7 (permalink) Old 05-29-2009, 04:50 PM
VulcRider24's Avatar
What are some good brands for LED boards for the taillight?
1994 Kawasaki Vulcan 750 named Jinba Ittai (Japanese for "Horse and rider in perfect harmony").
Jardine Pipes
Splines Lubricated
Painted Instrument Bezels
Headlight Visor
Chrome engine guard
Leather Fork Bag (contents: Pressure gauge, tools, and a Book of Psalms)
Yuaso MF AGM Motocross battery
Kenda Kruz Front tire
Duro Boulevard rear tire
"Buy the ticket, take the ride."
-Hunter S. Thompson
VulcRider24 is offline
post #6 of 7 (permalink) Old 05-29-2009, 05:25 PM
cglennon's Avatar
I upgraded both the brake/running (even made a second sissy bar mounted brake light) and turn signals to LED using Radiantz 1.85" dual-intensity clusters (search for my posts and pictures in the gallery). You can these clusters on at various online sites for $20+/piece with bases. However, they do show up on eBay for $3-$5/piece, which is where I got mine. I used the old bulb bases to make the connections.
Results are very bright, but somewhat directional as pointed out in earlier posts.
Chris Glennon - Portland, OR
cglennon is online now
post #7 of 7 (permalink) Old 05-30-2009, 12:18 AM
Love My Baby
rubyrick's Avatar
Radiantz makes an Eclipzed LED for the front turns. This model keeps the front running lights at 100% brightness and blinks off for turn signaling. This is different than stock turns which are 50% bright as running lights and blink to 100% brightness for turn signaling. Definitely worth looking into.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
