Stator replacement w/o engine removel? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 30 (permalink) Old 05-28-2009, 09:37 PM Thread Starter
Question Stator replacement w/o engine removel?
Was looking at Electrosport product details of ESG050 stator and universal fitting PDF appears to indicate it could be put in w/o engine removal. Anyone know if this is so?
Installation instructions have you cutting old stator wires, withdrawing old stator, threading new wires through grommet, fitting clips, hooking them to connection block and then, connecting up to and putting in new stator. This indicates to me connection block is in the housing under the grommet. Does this procedure really work on a Vulcan VN750A7 1991?
BillinAustin is offline
post #2 of 30 (permalink) Old 05-28-2009, 09:56 PM
fergy's Avatar
There are plenty of stator removers on this forum so one of them will probably pipe in here directly, but you do have to remove the engine, or at least unbolt it and tilt it to get the side removed and get to the stator. There is a mod you can have done if you send in your stator cover engine side where they slice it and fix it where you can open it up without pulling the engine, and I think it runs around $500.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 30 (permalink) Old 05-28-2009, 10:00 PM
The Professor
lance328's Avatar
That proceedure will only work on the vn700/750 with the TOC stator cover modication. If you don't have the TOC cover you will have to remove the engine.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 30 (permalink) Old 05-28-2009, 11:13 PM
Love My Baby
rubyrick's Avatar
I never understood why Kawasaki never modified their engine cover to allow stator removal without engine removal. It seems like such a logical modification. TOC deserves a big thumbs up for this mod, and Kawasaki gets a thumbs down for not licensing the mod from TOC and building it in to all their 750's. Too late now, anyway!
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 30 (permalink) Old 05-28-2009, 11:18 PM
I never understood why they couldn't have made the frame section removable on both sides and let the engine be a stressed member if they had to,wouldn't life be great then.And I still Love to drag My mouse across of the last part of your signature ,that never gets old.
post #6 of 30 (permalink) Old 05-28-2009, 11:28 PM
The Professor
lance328's Avatar
They could have done it but it was over looked, you have to remeber our engine was originaly designed to go into the 750 Ninja.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 30 (permalink) Old 05-28-2009, 11:30 PM
Have you looked at the new 650 ninja,I guess better late than never,huh?Kaw ,Not you
post #8 of 30 (permalink) Old 05-29-2009, 06:05 AM
Concert connoisseur
wib714's Avatar
i'm in the process now, engines gotta come out without the mod. good luck!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 30 (permalink) Old 05-29-2009, 08:40 AM
93VN750's Avatar
You have to almost completely disconnect the engine from everything no matter what. Taking it out only adds 10 moinutes to the job. I like working at bench level anyway. That's where mine is right now.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #10 of 30 (permalink) Old 05-29-2009, 09:31 AM
What about a 2004 VN750, Would the engine need pulled to do a stator replacement? Also, how long is the average life span on the stock stator. I'm mechanically challenged and nervous about this stator replacement thing...
John Brisson is offline
Tags
electrosports , stator
