Flashers not blinking - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 37 (permalink) Old 05-28-2009, 04:02 PM Thread Starter
nOObbobber's Avatar
Hey all
I have replaced my rear signals with "Auto Gem baby bullets" lights, two wire set up and they are not blinking. I am not sure if it means my relay is shot... All I hear when I engage the signal is a rapid clicking noise and the signal comes on but does not blink.
So does this mean my relay is dead?
Thanks
http://profile.imageshack.us/user/Fester42
1994 VN750
Tins/Head lamp - flat black
Front fender ditched
Rear fender bobbed
Powder coated rims
Recovered seat
Progressive 11.5" shocks
Progressive fork springs
Jardine "rumbler" exhaust - wrapped
Relocated horn
12" Z-bar ape hangers
Motion Pro Throttle Cables
Venom 110/90-19 170/80-15
Side mount License Plate/ Brake Light
Aftermarket signals
Speedo - Acewell
nOObbobber is offline
post #2 of 37 (permalink) Old 05-28-2009, 06:05 PM
Originally Posted by nOObbobber View Post
Hey all
Thanks
Does this mean the new signals light up, but do not flash?
Or does only the dash indicator light come on?
Will the 4 way flashers activate on all 4 lights?
Are the new lights LEDs?
Have the front signals previously been changed out for LEDs?
Did you test the lights to insure they would light before installing them?
If the flasher worked with the stock incandescent bulbs, it is likely still ok, but it may not be compatible with the new signals, if they are considerably higher watts.
Conversely if front and rear lights are both LEDs, they do not draw enough power to operate the OEM flasher. In this case you need a new one. I know lance posted a link for one previously. Check anyone who sells LED signals, they should have a compatible flasher relay.
In my autos, when the signal flasher unit blinks too fast, it usually indicates that too many bulbs are in the circuit. ie. If the flasher is designed for 2 bulbs, and I hook up a trailer, then the 3rd bulb causes a higher current (amps) draw, and the flasher heats up faster, causing it to cycle faster.
On the other hand, when the dash indicator light stays on when activated, instead of flashing, it indicates a missing or burned out bulb. The flasher unit also does not make any clicking when the light stays on.
So your rapid clicking of the flasher relay and the light staying on at the same time is counter to my experience.
If you can answer the questions at the beginning of the post, we can pin point where the problem is.
post #3 of 37 (permalink) Old 05-28-2009, 06:08 PM
fergy's Avatar
Very good questions Ol Hoss. I was too confused to try to answer his post! That should clear things up if we get answers.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 37 (permalink) Old 05-28-2009, 10:30 PM Thread Starter
nOObbobber's Avatar
Yes
Umm... no dash right now.. I took it off and have not replaced it yet.
hazards have the same effect, lights are continuous on and there is a rapid clicking noise coming from the signal relay. (no front signals.. I took em off)
incandescent
again no LEDs.. no front signals
umm... no.... oops
I am thinking they are lower watts... and with no front signals lower draw?
I am thinking this may be the issue since I eliminated the front signals and the new rear ones are much smaller, I think the bulb is a 14 Volt 0.27 Amp Miniature Wedge Base bulb.
thoughts? Should I find a different relay perhaps one for LEDs?
1994 VN750
Rear fender bobbed
Powder coated rims
Recovered seat
Relocated horn
Aftermarket signals
Speedo - Acewell
post #5 of 37 (permalink) Old 05-28-2009, 10:35 PM
The Professor
lance328's Avatar
Switch to an Electronic flasher unit. Most Auto Parts stores carry them.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 37 (permalink) Old 05-28-2009, 11:05 PM Thread Starter
nOObbobber's Avatar
Something like this perhaps?
Blazer/11-15 Volts 3 Terminal 2 Lamps for Turn Signal / 4 Lamps for Hazard Warning Electronic Flasher for Newer Import Cars, Trucks and Some American Vehicles
1994 VN750
Rear fender bobbed
Powder coated rims
Recovered seat
Relocated horn
Aftermarket signals
Speedo - Acewell
post #7 of 37 (permalink) Old 05-28-2009, 11:39 PM
The Professor
lance328's Avatar
Use the Tridon EP34 12v 3 Terminal electronic Flasher.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 37 (permalink) Old 05-28-2009, 11:49 PM
X2 to lance.
Did the OEM rear signals flash with the front signals removed? Logic tells me that the flasher relay should have interpreted that as a burned out bulb, and the rear signal stay on and not flash either.
post #9 of 37 (permalink) Old 05-29-2009, 12:23 AM
mine works with either end but it flashes faster with a bulb blown,seems I didn't read all the posts so excuse my lazy ways ,but if it is clicking too fast with the stock flasher it is because of low amp draw and Lance has given the best advice and that is an electronic Flasher that doesn't work off of a load but an internal timer.
post #10 of 37 (permalink) Old 05-29-2009, 12:32 AM
The Professor
lance328's Avatar
The electronic flasher will usualy cure: Fast blinking, Slow blinking and no blinking symptoms.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
